Hi there,
I can't erase fault code 444 on my ABS ..............I press the button on the ECU and hold it for more than 5 seconds. Nothing happens! The red light is not flashing at all. That means everything is OK, but then when I drive the car, the ABS light on the dash is ON!
Can anybody help with advise ?
Cheers
Stoil
Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
ABS fault code 444 problem
- billofdurham
- Year and Model: 855, 1995
- Has thanked: 0
- Been thanked: 3 times
Re: ABS fault code 444 problem
How are you getting 4-4-4 on the ABS check? ABS codes are only 2 digits. The attached shows how to read and erase ABS codes.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- Year and Model: XC70; S80; S40
- Has thanked: 0
- Been thanked: 2 times
Men, you've registrered in bulgarian forum... why didn't you surch there?!? Or even here - the first treat is: "How to use the On-Board Diagnostic (OBD) unit." In bulgarian forum the picture is the same - on top there is a treat abut the fault codes, puted all together on one place and a explanation of the way to read the codes in Bulgarian. There are members in Burgas who would be happy to give you a hand, another decision... your wish.
This is the treat: Eerror codes 4XX (in Bulgarian)
Good Luck
Translate:
Човече, регистрирал си се в българския форум... защо не си направи труда да прегледаш?!? Или пък тук - първата тема е "How to use the On-Board Diagnostic (OBD) unit.". В българския форум, картинката е аналогична: на първа страница на форума за 4ХХ е темата. Има ги всичките грешки събрани на едно място, както и обяснения как точно се четат. Има клубари в Бургас, който със сигурност ще ти помогнат, също е вариант... ти си знаеш.
Успех
Good Luck
Translate:
Успех
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
- Year and Model: 850, 1995
- Has thanked: 0
- Been thanked: 0
billofdurham,
Hey, on a 1995 Volvo 850, this is how we get the code:
http://volvospeed.com/CheckEngine.php
This is where we get the code info from:
http://volvospeed.com/Repair/a3.html
Can you tell me where the "Bridge" terminal connection is that "billofdurham" is talking about in the attached PDF - "440 ABS code""?
I have a 444 error code on my 1995 Volvo 850 "Canadian car"..... Any help on this 444 would greatly, and thank you in advance.
- billofdurham
- Has thanked: 0
Don't confuse your 850 with the Volvo 440 model that is being discussed in this thread. You can read the ABS codes through the socket A3 on your OBD. To read the ABS codes on the 440 it is necessary to bridge sockets 1 and 2 and the codes have only 2 digits. Do not bridge the sockets on the 850 as you may cause damage to the OBD system.
As stated in my reply to maora he can't have a 4-4-4 ABS code on a 440.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
billofdurham,
Thanks.... I figured it was something like that.
Now I wish I knew how to fix this issue.
It maybe time to take it to Volvo and let them figure it out.
1996 850 T5: DTC 335 & 444 on both US M4.3 & M4.4, not on EUR M4.3?
by Sommerfeldt » Mon Jun 19, 2017 4:11 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 9 Replies
- 1505 Views
Last post by misha
Wed Jun 21, 2017 2:36 pm
2000 V70 ABS-0011 ABS-0012 new sensor fault, Sensor to ring clearance bad
by Orchid70 » Thu Jan 31, 2019 1:20 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 27 Replies
- 3103 Views
Last post by Orchid70
Tue Feb 12, 2019 11:02 am
- 441 Views
Last post by britishrocco
Tue Sep 06, 2016 6:14 am
2001 S60 ABS/DSTC fault - need advice
by bjornas » Sat Dec 12, 2015 3:20 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 1 Replies
- 651 Views
Sat Dec 12, 2015 6:55 pm
