I wanted to post this for the benefit of others.
You do NOT need relay part number 213 "Fog Light Relay Jumper" for the fog lights to work on a 2000 v70 / s70
What you do need is a "J" jumper and "front fog light switch".
Tools needed:
socket set
Dremel tool or fine cutting tool
Instructions:
Step One:
Remove cover of drivers side kick panel by unscrewing single torx screw. Carefully push down kick panel till you have about one foot of clearance then gently pull toward drivers seat. Unplug courtesy light and toss the panel in the back seat.
This is where your midget contortionist skills come in to play.
Plug in "J" Jumper to Tan / Light Brown Relay port under dash.
Next to the steering wheel:
Pull off cover next to Rear fog light, behind the cover you will see a Yellow plug socket that is mounted to the cover. Remove the cover and replace with a Front Fog Light Switch.
With Key turned to position II turn on front fog light switch, if LED in switch lights up you are good to put fog lights on the car.
Step two:
You will need a Dremel tool or a way to cut a tabs off each side where the front spoiler grills are mounted.
Cut one tab clip on the outer most sides where the fog lights will be placed. ( If you mount the lights before you will see where the tab mounts will interferer with the lights staying flush)
Step Three:
Mount the Lights.
when you crawl under the car look for two holes that have no bolts in them at the back of the metal bumper. There will also be a small hole on the spoiler that will match up to the bottom of the fog light to mount it to the spoiler.
Take note if fog lights weren't there previous you might want to screw in the bolts once to stretch the metal. The reason I say this is because it will be hard to hold the light, socket wrench with bolt, and have it screw in with ease.
After lights are installed drive around like a PIMP and Ball like a G.
2000 v70/s70 Fog lights DON'T need 213 relay
figmentj13
- Year and Model: 2002 XC70
RIP: 2000 V70 SE <- Rear end while parked.
Faheyk1981
- Year and Model: Volvo V70 1999
Without this post i wouldn't of known about just needing the 'J' jumper. This is why i love this site. I too thought i needed the 213 relay and went out to buy it but then it wouldn't fit. I just installed the 'J' jumper and now works perfect! So all I needed was the fog lights/dash switch and a 'J' jumper. If it helps anyone else i drive the 99 V70 European model.
JRL
- Year and Model: Several
- Been thanked: 16 times
Good post, except you don't "cut" the grills, you just buy the proper (smaller) grills (cheap)
Hello, thank you in advance for this post, this issue regarding fog lights was driving me crazy, since my car did not a have a port for relay for fog light relay jumper 9148992. to me it was very difficult to put this 213 relay at the left top port so I finally and thanks to this post, I used the " J " relay instead, I finally did it dismounting wipers arms and getting acces to it from the top. Now i have front fog lights working. I dont know how to put photos but if you want some please explain me how to put them at the web.
cdnbluez
- Year and Model: 09 C30/98 V70/99 S70
- Been thanked: 3 times
I installed a pair of fogs today on my 99 S70. All I needed was one J relay, and a fog light switch. The 20amp fuse was in slot 17, and the grey light control relay was already there. No jumper needed. Easy install. $5 per foglamp at the picknpull.
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
2005 S40
2006 XC70
2014 Mercedes E350
- RigsPGT
- Year and Model: Red 99 S70 T5,
- Been thanked: 2 times
Can anyone please confirm if 98s need the 213 relay or not? Reason asking is that I removed a set of fogs, green relay and jumper out of a S70 that came with fog lights and I didn't see the 213 relay anywhere. I forgot to look at the year on this S70 but I'm assuming it was a 98 (same wheels as mines even though it was a turbo model). I was the first one at the junkyard to remove the kick panel and the fuse cover so maybe I won't need the grey 213? I just ordered the switch online so I have no way of finding out until I have the part.
EDIT: Now after installing the fog lights i decided to pop the fuse cover out and swap the green relay with the donor one. To my surprise the part numbers were exactly the same, only the side digits differed (don't have them here for comparison).
Do you think this would be one of those install the switch and have lights scenario?
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
- RigsPGT
After no luck with installing J Relay and 213 and some more research, it looks that the green 104/108 needs to be replaced with a grey colored 104/108. Now it's time to get the grey relay and sell both green ones. Getting there, slowly
Steve7071
- Year and Model: 1998 V70 AWD
I am adding fog lights to my 98 V70 AWD and have found everything I need from the junk yard except for the fog lights themselves. I have found new fogs that are fairly reasonably priced and will install those. The question I have is what type of screws are used to attach the fog lights to the car? Looking for size, length, type of thread, washer or no washer? Thanks for any help.
Mark60
- Year and Model: 1999 s70 GLT
- Has thanked: 2 times
I have a new set of foglights and a switch. I haven't looked under dash yet just been reading up on the install. 1999 s70 glt and the wire for lights and switch is in place. What exactly is the J relay jumper. I hope I can see what I need to do when I get under steering wheel to see panel .
Any advice much appreciated.
Thanks
Thanks
brianjdowd
- Year and Model: 1999 S70 GLT
Help -- I need the the "J" jumper & don't know where to find one. I have the fog lights, I have the switch, I have the new smaller grills, and I have the tools. Do I make a J jumper or buy a specific one? Electricity is NOT my forte!
Thanks, Brian.
Thanks, Brian.
- 2370 Views
Last post by msyverts
- 829 Views
Last post by ChickenCoupe
- 19 Replies
- 2702 Views
- 1689 Views
Last post by darylrobert
- 1419 Views
Last post by johnjbird
