Hi guys,
Im current having T5 and R but just saw someone selling his 2001 V70 XC 2.4T with 85k for a good deal. Im actually like the design on this model but totally have no idea about problems and concerns. Can you guys pls give me a short brief about this model? Might need to make a quick decision, pls help
thanks so much
from 850s to 01 V70 XC, what should i know?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It's an 01, AND an XC.
RUN AWAY!
I'm stealing this from another post, but:
RUN AWAY!
01-02's had 2 major trouble spots (3 for AWD):
1) Transmission. As jda2000 said, slightly better on the 2002 models if well taken care of. The 2001 ones have a stop-neutral feature that jerks the car in and out of gear every time you stop, and they all end up dying.
2) Electronic throttle - these all also fail; the question is just when. If it has been replaced under recall, you should be OK for a few years.
3) Mechanical AWD system can be problematic and expensive to fix if not properly cared for. The bevel gear and driveshaft are common failure points, begin making noise, and most people just end up running the car as FWD models.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
- Year and Model: Several
- Been thanked: 16 times
As was said...
DON'T
It's cheap because it's probably a piece of crap like 90% of all 2001's.
Keep your great T5 and R
DON'T
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
FCPGroton wrote:Burn the car to the ground and then run away!!!BEJinFbk wrote:And if you have a second thought,
Run Away FASTER !
Then get an ATTORNEY!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
Glencoeteen
- Year and Model: 00 V70R
RUN!!!!!!!!!!!!!!! STAYYYYYYY AWAYYYYYYYY!!!!!!!!!!!!!!!!!!!!!!!!!! they are EVIL!!!!!!!!!!!!!
98 V70XC~ Sold
98 S70 T5 ~ Stolen ;(
08 Xc90 V8 ~ Totaled
98 Expedition EB weekend warrior
98 S70 T5~ New project!
Glencoeteen
Find your self a nice 98 V70 T5 with the 5speed! you will fall in love!!!
98 V70XC~ Sold
- 1298 Views
Last post by benpineapple
- 16 Replies
- 846 Views
Last post by vtl
- 549 Views
Last post by a1jon
- 1238 Views
Last post by readallthebooks
- 31 Replies
- 6086 Views
Last post by Sveedy
