P0410 Code
I've read up on the issues associated with this code. I pulled the pump and it runs fine when hooked up to 12volts, even opened it up and it looks great! I could not see where there is a ground that is supposed to be coming from the pump. Bad selenoid maybe? As always, thanks!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
macs70GLT
- Year and Model: S70 GLT 1998
My car, 1998 S70GLT, threw this code last night for the first time. (also codes P0133 & P0455 - from before). I changed out the PCV hoses & oil separator last weekend hoping it might help with the other codes.Dave123 wrote:I've read up on the issues associated with this code. I pulled the pump and it runs fine when hooked up to 12volts, even opened it up and it looks great! I could not see where there is a ground that is supposed to be coming from the pump. Bad selenoid maybe? As always, thanks!
What is the pump in question, and where is it?
Thanks
Mike
Lars: 1988 245, 250K mi retired
Son of Lars: 1998 S70 GLT, 225K mi retired
Beast Mode: 1995 940T, 213K mi
Son's car: 1998 V70 GLT, 182K mi
Hans: 2002 Audi A4 QMT, 142K mi
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
The relay you mention is for the radiator fan (which has two speeds). The SAS relay is mounted near the pump itself and you access it from under the car. I replaced the relay and it wasn't sealed, so it's possible you can just pop it apart and visually inspect.
Since the SAS is designed to heat-up the catalytic converter faster, it won't affect the drivability of your car nor is it a necessary repair (unless you're a tree hugger!). Instead of repairing it, you may wish to do a search for removing the system completely - if you desire.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
I just repaired my air pump check valve/air pump relay for the SAS, I got the same code mentioned on my '96 850GLT. Before scanning for code I had no performance trouble whatsoever...the only symptom that was believed to be PCV system was some white smoke out the tail pipe. The check valve is between the fire wall/block, it's kinda got a mushroom shape to it and it's near the brake fluid res.. I couldn't hear anything coming from the air pump itself, so for now I'm leaving it alone.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
vjaneczko
Right. The SAS has no affect on performance at all. You can run with a dead SAS and a CEL on your dash and never hurt your engine one bit.shiloh51933 wrote: Before scanning for code I had no performance trouble whatsoever....
The pump should only run a few minutes at a cold start. If you hear it running when you get out of the car, then it's mostly the relay going out on you.I couldn't hear anything coming from the air pump itself, so for now I'm leaving it alone.
I swapped my relay and pump but left the check valve in place and it's still working fine. Of the three components that make up the SAS, the check valve is probably the longest-lasting.
2006 S60R - For ME!
2006 S60R - For ME!
- shiloh51933
I've heard/been told by many sources that the check valve is commonly the source of the pump failure...I got bigger fish to fry right now with doing the PCV system as soon as a good day presents itself.vjaneczko wrote:Right. The SAS has no affect on performance at all. You can run with a dead SAS and a CEL on your dash and never hurt your engine one bit.shiloh51933 wrote: Before scanning for code I had no performance trouble whatsoever....
Guys I've had my battery, battery tray and pump out but don't see any relay close to the pump. The wires off of my pump run to the connector and then the wires from the female portion of the connector splice into a bunch of other wires and off to god knows where. I thought that I read someplace that the relay was in the main fuse box and was the same as the trans. relay?
- 25 Replies
- 5864 Views
Last post by Gerd
- 769 Views
- 772 Views
Last post by rnelson1044
- 430 Views
Last post by volvo960sw
- 1040 Views
Last post by benpineapple
