tachometer not working
icelandic
Post by icelandic »
The tachometer in my 95 stopped working. Sometimes it wakes up and workss normally but the working periods are becoming scarcer. I think that what sends the signal to it is the crankcase rpm sensor. However if that is the problem wouldn´t the engine stop working? would´t it trigger a check engine light? Engine is working fine, fuel comsumption is normal. Anyone can shed some light into it? Thanks
1995 859 auto NA
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
I bet the solder joints on the back of the gauge is wearing out. The car is 16 years old.
icelandic
Post by icelandic »
It is apparently a very uncommon failure. I do not recall seeing any osimilar on the board.
Do you think it might be the sensor?
1995 859 auto NA
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
On your '95 you can put the cluster into test mode via OBD port A-7.
Put the flywire into port A-7, key to position II, and press the button 3 times.
The gauge should respond by showing the gas at 1/2 tank, temp to the bottom edge of the red, speedometer needle vertical (12:00) , tachometer vertical (12:00), and the mileage should advance by .5 miles.
To reset out of the test mode just turn the key off and remove the flywire.
That test should help you figure out if the cluster itself is messed up or it is a signal problem.
icelandic
Post by icelandic »
Thanks for the tip, Lee. However I just tryed it. Lead on A-7, Key to position 2, press buttom three times. Nothing happens at the cluster.
Icelandic
1995 859 auto NA
Post by Ozark Lee »
That should work. What happens if you just press the button once?
It could be that the lead is dirty or you may need to adjust the timing between "presses". When entering more than one button push I normally do it at about 3/4 second intervals.
Free2drive!
Year and Model: 2007 XC90
Post by Free2drive! »
Ozark Lee wrote:On your '95 you can put the cluster into test mode via OBD port A-7.
Well, my tacho is also messing about. Usually reads 2100 rpm, doesn't raise or lower!! So I am keen to see how the op resolves his issue.
Ozark...I tried your technique above and found the speedo reading 70 mph and the rpm reading 2100 rpm!! Both guages showing a line pointing at 11 am as if on a clock face. The other guages performed the way you explained.
Why does my speedo read 70 mph not straight up, and why is the tacho not working? Am I looking at an earth somewhere or a sensor?
Matt
94 turbo 855 auto.
Post by Ozark Lee »
Chances are the zero level on the gauges got messed up when the odometer gear was changed. That part really needs to be added a bit more prominently to the Odometer Gear Tutorial. Before putting the cluster back together the gauges need to be re-zeroed which is done by moving the needle all the way to full scale and then releasing it. It may take several times before it comes to rest at the zero mark on both the speedometer and the tach. At that point the face and the backplane of the cluster can be re-assembled.
Does your tach stay stuck on 2100 even with the key off? If so the needle is just stuck.
Free2drive!
Chances are the zero level on the gauges got messed up when the odometer gear was changed. That part really needs to be added a bit more prominently to the Odometer Gear Tutorial. Before putting the cluster back together the gauges need to be re-zeroed which is done by moving the needle all the way to full scale and then releasing it. It may take several times before it comes to rest at the zero mark on bot the speedometer and the tach. At that point the face and the backplane of the cluster can be re-assembled.
Thanks, I will pull out the cluster and strip down as if replacing the odo gear. Do I wind the speedo needle and tacho needle by hand and let go until they rest at zero?
Matt
Post by Ozark Lee »
That is correct.
