My question is has anybody replaced the lower fog lamps with projector driving lamps? or has anyone installed Rally lamps on the front of the Volvos? I wanted to mounted the roof racks and put some WRC lamps on there but I think the wife would have something to say about that
Fog lights not worth a damn. Ideas on driving lamps?
Red-Arrow
- Year and Model: 850 T5 1995
- Been thanked: 2 times
Yes I said it the Volvo fog lamps are mince. I drove through snow in New Mexico and the fog lamps didn't help me one bit. I've installed driving lamps on all my other cars and they fire out a laser beam of light down the road that won't dazzle oncoming drivers.
Life would be enjoyable if it wasn't so painful to live.
JRL
- Year and Model: Several
- Been thanked: 16 times
Many have
You can install an HID fog kit or an HID driving light lit
DAMN straight!
DAMN straight!
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Consider a set of projector headlights and you won't need the rather useless driving lights below the bumper.
As for driving in snow and fog, roof mounted lights are not a good idea, you want the light source as low as possible to reduce the back scatter - Mike
toddv850glt
- Year and Model: '95 850 GLT
I installed a set of H.I.D bulbs in the stock lenses and was a great change in vision. I have an NA 850 without foglights but put in my own with costom bracketing in the place where they usually would be. I got a set of H.I.D lights for that too. Wow what a difference and will never go back to halogens. Piaa offers a nice bulb replacement for the headlights and a HID light system too. I also took the time to install all LED bulbs throughout the car. I put them in the stock tailights ect. and they are brighter and respond quicker. I also put LED super whites in the interior lights with a little wiring and resistors you can totally see alot better inside.
'95 Volvo 850 Glt N/A 5spd.
'96 Pontiac Grand Am
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
E-code lenses and/or Silverstar bulbs.
My S70's headlights were awful before; I fitted some Silverstars, and my nighttime vision was MUCH improved.
'98 S70 T5
2016 Chevy Cruze Premier
zhenya
- Year and Model: 97 855 T5,98 V70 AWD
This is what I was getting at above. Replacement e-code lenses for the 850 are dirt cheap, and will revolutionize your night vision. This is the first thing I'd do, bar none. With regular bulbs, my high-beams are better than the HID's on my previous Audi, and better than my wife's much more modern Subaru.jablackburn wrote:E-code lenses and/or Silverstar bulbs.
thecheat
- Year and Model: 1996 850 Turbo Wagon
Can you use the e-code lenses with the original DOT reflectors? I thought they needed to be changed as well?
Anyone bought the real HID retrofit kits with the ballasts? There are some dirt cheap kits on Ebay... like $50 shipped!
Red-Arrow
I shouldn't post threads at 6am. Dam:lol:
I don't want fog lamps but driving lamps which have a narrow long throw beam. In the UK and Europe its normally illegal to have driving lamps below the bumper as bad alignment can blind oncoming drivers. Driving lamps are or should be installed above the bumper and the higher up they are mounted the better the light angle is for road illumination.
I have been looking for driving lamps that will mount above the bumper but ones that won't look tacky?
Maybe installed into the grille each side of the Volvo badge? I just don't have the time or a dremel to customize my grille or make mounts. Has anyone here done something similar to the below pictures?
- 1417 Views
Last post by Brimstone
- 5540 Views
Last post by AnyMajorDude
- 1104 Views
- 994 Views
Last post by virginiavolvolover
- 1007 Views
Last post by obayha
