ANyone know what code E-02 from the radio means when i try to use the CD changer? Changer is NOT jammed and does eject and fuse is good.
Thanks
CD changer fixed!!! (for now at least)
Guest
Hey fiddy, Mine just the other day had the same code, not sure the tech..def of the code but I discovered mine was throwing the error because there were two cd in the same slot #2. Removed all cd's and plugged it in and it played with no codes. Put the other five in and have not had a problem since. Hope this helps, Good Luck
Thanks Guest, I opened up the cd changer and realized that a cd was already in the player (from previous owner) so I removed and filled the cartridge with CD's. Now it won't pull the CD all the way into the player, it starts to but then puts it back and tries the next one, all six of them but doesn't take. What now???
Ok everyone I fixed my CD changer. This afternoon i removed the cover (7 little screws) and lubricated everything with silicone (gears,etc.) then drove around and it wouldn't play CD's 1-3. Well after some time I changed all the Cd's and it's working better now, a little slow reading but nonetheless it "accepts" all the 1-6 CD's and sounds great!
- 4972 Views
Last post by pbierre
- 542 Views
Last post by MDK
- 928 Views
Last post by precopster
- 13 Replies
- 2471 Views
Last post by ferocity02
- 981 Views
Last post by mrjacobrussell
