Leaking Transmission Line Leak
sven
Year and Model: 03 V70 97 850 R.I.P
Post by sven »
I did a search and couldnt find much on this. My upper transmission cooler line is leaking at the crimped end...where the rubber meets the actual metal line. Where can I get a new hose? I searched the usual suspects but couldnt find anything.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
UPPER?
That's not common, usually the lower line is the leaker!
I suppose you would buy one at a Volvo dealer, that would be the "usual suspect", don't you think?
sven
Post by sven »
Yup upper. Its leaking at the crimped end toward the transmission, not the radiator end. I can literally see it dripping when idling. I checked tascaparts.com but I cant figure out what they call the part. I dont like dealing with my local dealer.
Anyone know the part #s for both upper and lower? I guess I could have a hose shop rebuild my lines...Ive done this with other cars/tractors.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
I believe the p/n is 9180542 (up), 3507931 (low).
http://www.myvolvopartsonline.com/partl ... eid=215507
I would call to make sure fits your car.
BTW, the o-rings come with it if thats Volvo's.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
sven
Post by sven »
Thanks Al, those are the correct #'s. IPD sells them for about 100 each. Tasca has them for around 73/ each. Not too bad I guess.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I've been monitoring my automatic transmission outlet hose for a few months now. It is slowly leaking, coating the metal part of the hose in leaked transmission fluid. I've found that Tasca still seems to have the lowest price ($80), with eeuro ($97), IPD ($102) and FCP ($105) coming in higher.
Could someone who has done this replacement offer me up some guidance or advice? I was wondering what kind of fastener(s) need to be removed at the transmission, if there any any gotchas or other tips / tricks to observe. How hard is it to route the new hose in place?
Thanks!
wheelsup
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
I would call a NAPA or Car Quest. You can probably have them rebuilt for a lot less than that. To remove you just undo them at the transmission, they are flare type fittings IIRC. No o-rings on the transmission side, just pressure fit.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I think there are O-rings at both ends (rad + trans sides). See photo.
Use only Volvo O-rings, a few dollars at dealer.
Now the hose itself:
1. You can buy Volvo hoses (#29 #30) but they are about $90 each.
2. I have seen people do this in other forums such as Honda:
- Remove the old leaky hose.
- Cut the rubber hose off but keep the metal connectors.
- Find a suitable hose (a few dollars at autoparts store), cut to length.
- Re-attach using standard clamps.
Remember the ATF pressure is very low, about 5-10 psi max, so a standard hose + standard clamps will be fine.
I posted the idea of using standard hose here, see post from Apr 2010:
https://www.matthewsvolvosite.com/forums ... =1&t=28806
Example from Jeep forum:
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
What car is this for? I have a used set of transmission cooler hoses for an 850 in my garage.
jreed
Post by jreed »
Thanks guys. I'm grateful for your pointers, advice and offers. I'm planning to do this repair for my wife's car, a '97 855 GLT with ~160k miles. I'm going to go with the OEM style solution. I'll use the Volvo o-rings. I don't know if a new hose comes with the o-rings or not. I'll check with Don Snyder and/or Tasca to be sure.
I'm thinking that in the course of doing the line replacement, I will be draining most or all of the transmission fluid out, measuring it, and then refilling with an equal volume of fresh ATF when I'm done.
