2002 V70XC - battery light/low voltage
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
sheofennui
Year and Model: 2002 V70XC
Post by sheofennui »
I was driving home and the battery light came on along with a message that said something like E.L.System Service Needed. I turned off the heat and radio, and eventually the light and warning went away. Then a couple of minutes later I got a yellow exclamation point in the center of the instrument panel and a message that said Battery Voltage Low. I also notice a lot of clicking noises coming from the dash. Any thoughts on what this might be? Thanks!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Sure
Bad battery
Bad alternator
...or both
sheofennui
What do you think the clicking noise in the dash is? It sounds like a switch repeatedly being turned on and off with no particular pattern.
JRL
Post by JRL »
Probably an AC vent flapper motor
One of the diverters is stuck or broken
