850 Manual Trans "Shutter"
jdsmith
- Year and Model: S60 2006, 850 1997
I have a 1997 850 with a 5 speed manual transmission. Recently I noticed that when I take off from a dead stop in first gear, it "shutters" for a few seconds. If I increase the RPMs before engaging the clutch, there is no shutter. The motor mounts are new, the tires are new. Is it my clutch? Can the clutch be adjusted?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Start out around 2000 RPM in 2nd gear and floor the gas pedal. Do the RPMs rise a bit without the car accelerating in turn? That would indicate a clutch beginning to fail.
Next test: leave the car in neutral with your door open and release the clutch pedal. Does it begin to make a whirring noise? That one would indicate a throw-out bearing.
Either can cause some shuddering, and the clutch on the 850's are not adjustable like on older cars as it is a hydraulic system.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
- Year and Model: Several
- Been thanked: 16 times
Clutch and/or your flywheel
Same labor for both, so you may as well replace everything
- 27 Replies
- 3615 Views
Last post by precopster
- 727 Views
Last post by mgett181
- 909 Views
Last post by kriticalchris
- 667 Views
Last post by Ozark Lee
- 17 Replies
- 7864 Views
Last post by beigg
