1998 V70 R - Low Intake Manifold Vacuum
scoobycant
- Year and Model: '98 V70 R
194,000 mi on odometer. Starts, idles, and drives nicely. No check engine light. But I'm measuring a steady 14 inHg vacuum at idle with warm engine. Cylinder compression #1-5 are 178-180-175-178-180. New vacuum elbows at passenger side intake manifold, SAS valve, SAS solenoid. Tried propane to check for leak - found none. Any way to check for exhaust restriction? Thanks in advance.
'98 V70 R (Saffron) 208k
'99 V70 XC (Silver) Sold
'99 S80 T6 (Blue) Sold
JRL
- Year and Model: Several
- Been thanked: 16 times
Has the COMPLETE breather system been replaced?
How many miles on the Cat Converter?
scoobycant
COMPLETE breather system replaced with new factory parts less than 3,000 miles ago. I measure 2.5 inWC vacuum at dipstick.
Catalytic converter, pipes, mufflers are original.
JDS60R
- Been thanked: 3 times
You can drill the exhaust pipe before and after the cat and test for pressure. I got tired of drilling so I mocked up a metal plug that threads into the oxygen sensor bungs.
An easy check is to create and exhaust leak after the turbo. You can loosen the pipe or just remove the O2 sensor while checking intake vacuum. This should be done with extreme precaution towards fire being ejected through the O2 hole. Be prepared.
You might want to go under the car and smack the cat converter and muffler - only when cold to check for rattles and broken baffles. Many folks do not change the 02 sensor often enough and a damaged cat or bad muffler baffle may exist.
Retired
scoobycant
Thanks for the info. I'll do the smack test first. Then I'll drill the holes. What is the acceptable/bad differential pressure across the catalytic converter?
JDS60R
Measurement in front of the cat shows cat building pressure. measurement after shows muffler building pressure. A good performance exhaust should be far under 1 psi.
Retired
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
14 inches vaccum is not really low for that car. The turbo is loading the engine a bit at idle and if you measure pressure on the turbo control valve hose from outlet of turbo you'll find .25 psi +/-
High compression engines with lower idles speed and no turbo will go 20-22.
The S40/V40 4 cylinders are hard pressed to get 10 inches vac.
Retired MVS Contributor
Low vac in turbos is the reason why heater controls are not vac, but electric...
Glencoeteen
- Year and Model: 00 V70R
hmmm still turbo or not only 10lbs at idle on a turbo doesn't sound right, I am thinking you have a pinched/leaking Vacuum line to your Gauge, my 98 T5 has 210k and @ Idle is at 20lbs then shoots up as soon as i accelerate. and i just installed it about a month ago,
98 V70XC~ Sold
98 S70 T5 ~ Stolen ;(
08 Xc90 V8 ~ Totaled
98 Expedition EB weekend warrior
98 S70 T5~ New project!
- 1063 Views
Last post by bmdubya1198
- 1547 Views
Last post by erikv11
- 752 Views
Last post by JimBee
- 706 Views
- 1304 Views
Last post by 98v70xc206
