1999 V70XC abs discontect
tjg
- Year and Model: 940 1995,XC70 1999
- Has thanked: 3 times
Think I'm having a intermittent abs problem, get a wobble around 30 to 40 mph and rumble when turning corners. Is it possible to discontect the abs ( as simple as removing the fuse from main box) and still have the brakes work, so I can tell if this is the problem.Thanks
1995 940 TURBO SW
1995 850 TURBO SW
1999 V70CX
Previous
1993 940 TURBO(CRUSHED BY TREE)
1989 240(CRUSHED BY SAME TREE)
1972 142 SOLD
1995 850 TURBO SW
1999 V70CX
Previous
1972 142 SOLD
JDS60R
- Been thanked: 3 times
Yes. The brake will function without ABS if the unit is powered down or disconnected. Be prepared for several ABS, traction control,stability control codes to be set. Make sure your machine can erase them
Retired
JRL
- Year and Model: Several
- Been thanked: 16 times
Wobble and rumble?
Your propshaft has gone bad, not your ABS
tjg
JRL by wobble I feel the car shake side to side between 30 to 40 mph and grinding noise at the front end when making turns at corners. Replaced the propshaft last summer(colorado drive shaft).
1995 940 TURBO SW
1995 850 TURBO SW
1999 V70CX
Previous
1972 142 SOLD
1995 850 TURBO SW
1999 V70CX
Previous
1972 142 SOLD
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
It does sound like classic drive shaft trouble.
You might take a little time and pull the shaft
to see if the problem goes away. Cheap test.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
You can pull the fuse if you want, but I'm 99.9999% sure it has nothing to do with any of the issues you speak of.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
JRL
Can't on a 99, the car won't run.Matty Moo wrote:You can pull the fuse if you want, but I'm 99.9999% sure it has nothing to do with any of the issues you speak of.
(98s and earlier are different)
Had the same noise on my 1998 v70 and my 2000 v70...took out the propeller shaft, goes from front of car to back to power the AWD....called Colorado driveshaft and they sent mt 2 remanufactured ones for 1140, they will pay return shipping, and return a core charge of 75.00 for each shaft...great guy's to do business with...get hold of Dave...he set me right up.
coloradodriveshaft.com phone number is.....303-297-2928
- 669 Views
Last post by FLXC90
- 16 Replies
- 3040 Views
Last post by precopster
- 1455 Views
Last post by tsteenka
- 27 Replies
- 14395 Views
Last post by Orchid70
- 19 Replies
- 3762 Views
Last post by sak54757
