99 S70 T5 Starts up, then dies - Not Antenna Ring?
ColonelCash
Post by ColonelCash »
Alright folks, seems like we have quite a few "my car won't start" threads and I haven't been able to pinpoint another issue quite like mine....so here goes.
99 S70 T5 - I go to start my car on Friday night it suddenly wouldn't run. The car would start up without a problem, then quickly sputter out (2-4 seconds). Try the car again, same result. Removed key, reinserted key and again had the same problem. I started Googling some possible scenarios and all signs pointed to an Immobolizer failure (Antenna Ring replacement). Today, I get the new ring from DW Volvo in Franklin and install the part. No dice, same exact result. Now, I can mash on the throttle when it starts up, but that only buys me an additional second at best. The battery appears OK and it seems to be getting juice from the alternator. The battery is 3+ years old though, but I've had batteries die and this isn't the same type situation.
I have not seen any warning lights come on, although I haven't ran for codes since I do not own a scanner. The car is stuck in a parking garage until at least Tuesday night. Is there anything else I can try to get the car running? I'm not exactly mechanically inclined, but can poke around and have little fear in removing parts on the car. Pretty sure I have removed every screw on the front dash in the last 2 years.
I have a pretty solid mechanic in the Nashville area, but always like to get some direction from MVS before handing it over.
Thanks in advance,
David
JDS60R
Been thanked: 3 times
Post by JDS60R »
David,
I'm also in the Nashville area. If the antenna ring is functioning you should not see any flashing alarm light on the dash.
The coil on plug ignition can fail but rarely all coils at once so we are down to compression and fuel.
I doubt your compression magically went away all at once so we have fuel and ignition triggering.
If your fuel pump relay is gone then put in a replacement and be on your way. If the pump doesn't power up then it needs a check for power and replacement .
If the entire fuel system is working you have to see why it would fire and fail from the ignition side. This normally comes down to the cam sensor.
Lurking in the background is the MAF.
Does the car give any codes?
Can you hear the fuel pump power up when you turn the key to position 2 (II)??
When was your last fuel filter change???
Any problems other than this before it finally refused to start??
Retired
JDS60R
Post by JDS60R »
I have a scanner and can be bribed with gas money etc
Retired
ColonelCash
JDS60R wrote:David,
I don't recall seeing anything on the dash after replacing the antenna ring, but I still have the car apart and can switch the old one back in, if needed.
I didn't think to check the fuel pump, but I can do that. Unsure of last fuel filter change, but would suspect it was maybe a year ago? Had the engine basically rebuilt and it has performed great until now, and I don't think this is engine related. No other major problems, although I did see some posts about MAFs going bad. I figured the antenna ring was a cheap possible fix, so was worth a shot before getting the car towed to a shop. I might give the fuel pump relay a shot as well, I have some time before it needs to be towed.
ColonelCash
JDS60R wrote:I have a scanner and can be bribed with gas money etc
Haha, might have to take you up on this one if I exhaust all options! Good to see some other Nashville area folks on here.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
This is where I'd start - quick, simple test. Unplug the connector and see if the car will run/idle at all.
'98 S70 T5
2016 Chevy Cruze Premier
ColonelCash
Thanks for the tip. Is there an engine diagram where I can find the MAF (or photo would suffice)?
jblackburn
It's the round sensor thing on the hose that leaves the air filter box and dives down to the back of the engine.
'98 S70 T5
ColonelCash
jblackburn wrote:It's the round sensor thing on the hose that leaves the air filter box and dives down to the back of the engine.
I found this through a Google search on MVS:
https://www.matthewsvolvosite.com/forums ... =9&t=26833
I'm assuming the s70 will look somewhat similar?
Thanks for the help!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
How's your ETM? (throttle body)
When they fail, they don't always throw a dash code
