I finally got around to pulling the head off the motor i took out of my car. It apparently seized due to lack of oil so the bottom end is toast but I am pretty sure the head is still good. It wasn't the most well maintained motor obviously so i would like to clean up the cam cover and clean up the head. i have never pulled a head before so I dont know what to clean it with or how to store it.
I've heard of chem b-12 and some other stuff. what should i use to scrub it with that won't damage the mating surfaces?
Should I take all the valves apart to clean all the carbon deposits? Most likely I would put new guides and seals in before I ever installed it on another car but I would like to know what I should do to clean and store it right now. It has 154K on the motor and there was no head gasket leak.
Also is it normal for there to be valve marks on the intake side of the pistons? there is two marks on each piston so I dont know if the head has been rebuilt or not cause none of the valves are bent.
Thanks for any suggestions!
Andrew
pulled cams and head...what to clean it with?
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
JDS60R
- Been thanked: 3 times
Do not scrub the head. Remove the gasket chemically. You do not want to alter the RA finish of the head or block. Use an old credit card or plastic razor blade to move the chemically removed goo. Then wipe the rest with a lint free rag.
Gasket remover is a spray on gel type. Then finish with brake cleaner or similar cleaner that does not leave a residue.
By leaving the same finish on the metal and removing any gasket , oil or residue from the mating surfaces you professionally installing some longevity into the seal.
None of that will matter if the surfaces are not flat. Make sure to take you measurement on the block and the head and have resurfacing done as needed.
Retired
- 614 Views
Last post by Olegs855R
- 1161 Views
Last post by 454cid
- 2699 Views
Last post by kallekula
- 3979 Views
Last post by Jraptor2000
- 2715 Views
Last post by Karpov
