2007 C70 Transmission fluid
JRL
- Year and Model: Several
- Been thanked: 16 times
No it doesn't.
It says 3309 fluid
If you can find it: MOBIL 3309 IS Volvo fluid but when Mobil labled, it costs about 6 bucks a quart
Volvo buys it from Mobil, relables it and charges 16-18 bucks a bottle!
The other fluid you can buy (also 3309) is TOYOTA TYPE IV, SAME STUFF
This is not a synthetic fluid but it has special properties for Aisin Warner transmissions and you must use it
It says 3309 fluid
FCPGroton wrote:Both of these will work. I have also heard that Valvoline trans fluid works to but I have not verified that.
Valvoline's website says the Maxlife fluid meets Toyota/Lexus T-IV specs, but doesn't mention Volvo. I have seen where people say they are using it, but to me with the Toyota fluid basically as readily available and as cheap (I wouldn't)..
skeeter123
- Year and Model: s60, 2004
Valvoline .pdf spec sheet does claim "Volvo passenger car applications", and the FAQ section does say Volvo.....
http://www.valvoline.com/pdf/Maxlife_ATF.pdf
But i just went by the Toyota dealer and picked up a case (12 qtrs) of Toyota T-IV for my next flush. I try to flush a little over 11-quarts through, have 1/2 to 3/4 quart left over for topping off. '04 S60, NA.
Actually it says JW8 as listed in this link. 2007 C70, So JW8 is still 3309 and not synthetic like the Volvo dealership is telling me?
http://new.volvocars.com/ownersdocs/200 ... .htm#pg238
JRL
3309
VOLVO FLUID AND
TOYOTA FLUID
IS NOT SYNTHETIC AND NO VOLVO FLUID IS SYNTHETIC
ASK YOUR VOLVO DEALER TO SHOW YOU ON THE BOTTLE WHERE IS SAYS SYNTHETIC?
ANYWHERE......
Then tell him to STOP telling people it's synthetic or you will sue for giving false information in the product they're selling
VOLVO FLUID AND
TOYOTA FLUID
ANYWHERE......
Oh I would love too! So back to the link, what is JW8? and why does it not say 3309? I just want to be sure im using the right stuff...the last thing I want to pay for is a new transmission. And how can the dealership charge $33 when they as you stated charge 16-18?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The fluid type is JWS 3309, there is no JW8 or JWS. Volvo is not immune from typos.
If you go to that site and pull up a 2007 S60 which uses the same gearbox it lists jws3309
pulled from that source:
Fluids
Transmission1
Oil grade
Manual: MTF 97309
Automatic:
AW5
TF-80SC (S60R)
JWS 3309
JWS 3309
OK, cut and paste didn't pick up the column chart.
Fluids
Transmission1
Oil grade
Manual: MTF 97309
Automatic:
AW5
TF-80SC (S60R)
JWS 3309
JWS 3309
Now that I looked at it again i think it does say JWS, and must be a typo as you stated. How in the hell can the dealership get away with saying its synthetic and telling me its $33? I guess cuz there the only Volvo Dealership in vegas and what happens in vegas stays in vegas!
- 1104 Views
Last post by theWIFES_S70
- 1792 Views
Last post by Samzebian
- 11 Replies
- 4734 Views
Last post by chrism
- 516 Views
Last post by Krons
- 1426 Views
Last post by RickHaleParker
