Help with 19x8.5 rims
850 Turbo Timing Belt, Water Pump Replacement Marathon
Does anyone know if I can run a 19x8.5 rim with 215/35 19 tires on my 1997 850R without any modifications to prevent rubbing?
JRL
- Year and Model: Several
- Been thanked: 16 times
Probably not
precopster
- Year and Model: Lots
- Been thanked: 128 times
My 7.5 inch rims force the tyre to rub at both left & right lock on the inner liners (both front wheels) when the tyres are actually LEVEL with the outer edge of the mudguards.
Tyres in use are 205/50/17 though ideally they should be 45s to retain stock rolling circumference.
At the rear you can squeeze 235s on 7.5 inch rims with the correct offset but just remember that a 8.5 inch rim is designed for a at least a 255mm width.
The 215 size tyre will look cone shaped when fitted to a 8.5 inch rim & I doubt the tyre fitter will fit them.
