'96 Ignition key problem
karltheozy
Year and Model: 850 ,2x94,2x96
Post by karltheozy »
In Australia we get a key with a '96 850 that looks normal but has the letters "Ymos" and nothing else engraved on it .
My New ( but now old ) 850 Wagon ('96) has a Bug !! - -
I start it easily 90% of the time - - Bu the other 10% bothers me - - , changed most Electrical Parts - -Plugs / wires / Dizzy cap / rotor button - - but no difference- - - The car will Start ! but will not run - - only the starter motor and a brief Brrrm .
The I came to an Article on Bay 13 ( I think ) that suggested that if the Key ( Yes the key !!! ) was dodgy -- or the Antennae/Aerial loop inside the Steering column wasn't good ( Again !!! ) then the security code in the key handle would not transmit to the Computer in the car .
Completely "Noplussed" I sit back and think - - - I don't need so much security on a 15 year old car that It will stop the car from starting .
- - does anyone know a way to disable this feature without destroying the cars computer .
I also need a second key because the previous owner cared so little he threw the other one away - -and the Volvo dealers here are so poor they need to Charge US $200 for a new second key ! - - -, This ones driving me mad any answers ?
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I'm not sure about the Volvo's down under,
but chipped keys didn't arrive in the states
until the '99 70 series. I don't think you have it...
I suspect there's something else amiss . Codes?
karltheozy
No - - Had this one Verified by a local Locksmith when I took the key to him for a duplication - - I needed a second key - - .
Locksmith pushed the key into an electrical box - - Key Gizmo - - he said it had a chip in it and that all he could cut for me was a
door lock key that would not start the car !!
I thanked the guy and checked with the Dealer about the Key cut / coding price .
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Take us a picture of your existing key - NO 850's that I know of had a chip in the key.
Someone here should be able to identify immediately whether or not your key has a chip. 850 keys were very skinny; 98 keys were a little fatter; 99 keys (with chip) were even fatter than mine.
Your key would be even fatter around than this one if it contained a chip.
'98 S70 T5
2016 Chevy Cruze Premier
karltheozy
I have to maintain two '96 850's both standard models - - both with the same type key - -
In this picture My wifes much older 940 key is the pointed plain handled key - - - - .
The much bigger thick handle ( nearly twice as thick ) is the 850 key .
940 key is much smaller and nearly half thickness - - -
I hope the Image shows up - - !
I also have had 2 x older 850's - - 93 and 94 - - they have smaller thinner key handles that do not have chips and look like the examples you have put on line .
Cheers Karl
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
There are afew dealers of used parts in Oz other than Volvo factory outlets. What's your location??
diyer97
Year and Model: 960 97 138kmiles+
Post by diyer97 »
my 97 960 SW got big, fat keys but no transponder,the chip, or it's embedded that I couldn't see it. My neighbor's Lexus ES broken key still starts her car with one hand using a needle nose plier and turns while other hand holding the broken handle with the transponder to the key insert channel.
jblackburn
Hmm. That looks like it might actually have a chip in it. If so, your next step would be to call a dealer and ask if there is a part number for an "ignition antenna ring" on your car. This is usually the problem the newer vehicles have communicating with the key.
'98 S70 T5
karltheozy
Thanks for Input so far - - -but I am trying to avoid being hung out by the dealers ( In Australia - -particularly Sydney - - they take you down badly price wise !!) and unfortunately the Local Parts recyclers and Importers would still have to get the key reprogrammed by a dealer - - - after all this does anyone know if the Key Chip lockout system can be disabled ??
I haven't yet figured out how to access the computer ( other than where to plug in my shiny new OBD2 reader - - ) but I have access to an old ( Non Security chip) 850 which I can play around with . To quote the teacher in Ferris Bueller - - Anybody - - Anybody ??
BEJinFbk
Post by BEJinFbk »
karltheozy wrote: I checked with the Dealer about the Key cut / coding price .
Did the dealer confirm that Australia gets coded keys?
I'm still having a hard time believing that...
FWIW, my '98 V70 key also has the Ymos imprint
and I don't have a coded ignition. Just seems odd...
