2001 S60. I ran Seafoam through the intake per the instructions here: https://www.matthewsvolvosite.com/2010/0 ... -followup/. Lotsa smoke! The idle was irregular before (drops, then rises) but now it drops so low as to almost stall every "cycle". The interior lights dim and everything. Did I break something?
CEL light is on, but it has been for a while (trans is bad, getting fixed soon) so I've been ignoring it. I pulled the code now and it's reading PO237, low input voltage for the turbo? I reset it and it comes back on immediately.
Seafoam...now idle is horribly irregular
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Hold the idle steady with your foot and check the alternator's output voltage. Low voltage can cause all kinds of weird things to happen.
'98 S70 T5
2016 Chevy Cruze Premier
priapism
- Year and Model: 01 S60
The alternator reads perfect, right around 14.5-14.8 or so when idling. Battery is strong, 12.5v.
It idles perfectly when cold but the idle gets all wavy when it's warmed up. Drops to 6-700 the pops up to 1k. Every so often it drops so low as to make the whole car judder. Man, I thought seafoaming the intake was supposed to FIX this.
Codes come back immediately after clearing too. 237 and 236. Ugh!
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
JRL
- Year and Model: Several
- Been thanked: 16 times
May have messed up the MAF
(Or it was going bad and this helped it along)
JRL
CAREFULLY
skeeter123
- Year and Model: s60, 2004
Those codes could point to the MAP sensor; maybe the seafoam didn't agree with it, or maybe you could check the wiring/connector to the MAP.
Hope this helps.
check out:
https://www.matthewsvolvosite.com/forums ... r+#p135453
Hope this helps.
check out:
priapism
No kidding...JRL wrote:CAREFULLY
Yeah, I touched the sensor when I picked it up, think I broke it. Ha! It's much worse now. Time for a new MAF. I was thinking I should probably replace it anyways.
JRL
You need to remove the TB to properly clean it
Make sure you buy a new gasket
- 799 Views
- 1380 Views
- 7989 Views
Last post by tigerpaw458
- 602 Views
Last post by Ozark Lee
- 11 Replies
- 2833 Views
Last post by MarcM
