Help! I need the correct procedure to replace the pressure power sterring hose in a 1999 Volvo S80 T6. What parts do I have to remove to connect the new hose? I was only able to remove the old one by bending it and cutting it. I just can't figure out a way to snake the new one in.
Thank you.
How to replace power sterring hose S80 T6
Compartment under glove box is broken
jaimecortes
- Year and Model: S80 T6 1999
Good luck...
I had the same problem and I ended up replacing only the damaged area in my case was the connector/hose section next to the pump. What I did, I purchased a pression connector( is in mm's so you need to order online, I could not find it in town), and used a mini plumbers pipe cutter and only replaced that bad area...
Good luck
Good luck
- 861 Views
Last post by TrstnBrtt
- 1063 Views
Last post by volvooh
- 14 Replies
- 5198 Views
Last post by coded9
- 6750 Views
Last post by FlyingVolvo
- 2831 Views
Last post by BigSpud
