I got a call from my wife this morning and she said that something really big broke on the '94. I took her my daughter's S70 to keep her moving and tried to drive the '94 home - I made it about half way when the frikking left front wheel came off. As I was driving it I thought it was an axle that was falling apart. After the last lug stud came out the car obviously lost drive but fortunately the wheel didn't completely fall off of the car, it held on the locater pin.
Finding lugs is a challenge beyond the dealership but Car Quest had them. I bought 5 new lugs and took over a jack to put the wheel back on.
The rub is that one of the threads on the hub is buggered up so I drove it back home with 4 lugs.
I am set up to get the threads chased out on the hub at KC Autosport on Monday morning but does anyone know what the stud threads are? I took the stud into Lowes and it seemed to fit both the M-12/1.75 and the 1/2" / 13 test nuts in the hardware department.
The only thing I can figure is that someone was trying to swipe the wheels and got scared off, leaving one lug on the wheel. Everything was fine until this morning and I don't buy that all of the lugs fell out without warning.
One of my wheels fell off
- Year and Model: Many Volvos
- Been thanked: 76 times
cdnbluez
- Year and Model: 09 C30/98 V70/99 S70
- Been thanked: 3 times
You're lucky she called, my wife would have kept on driving! "Noise? What noise?"
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
2005 S40
2006 XC70
2014 Mercedes E350
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Why the @#$@^ would you try to steal the wheels off a Volvo? Well, at least it didn't fall off and you crashed!
You'd almost think you live in Durham, Lee.
'98 S70 T5
2016 Chevy Cruze Premier
confused_al
- Year and Model: 1996 TLA wagon
I know exactly how that feels! I had one fell off my MB last summer, since some moron (dont ask who
) forgot tighten the lug bolts on one wheel after replacing brake fluid. I was lucky the damage was minimum, only one thread was massed up and I was able to tab it out.
The size is M12x1.75.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Mbnorris
- Year and Model: '01 S80 T6 Executive
I've been a machinist for 15+ years so I think I can help. If the stud you have screws in both M12/1.75 and 1/2-13 nut then I'm bout 90%+ sure that you have a M12/1.75 stud. Only 90% because you just don't know how many times a bolt has been screwed in and out of those thread checkers at Lowes. Converting metric to English to help simplify.
It breaks down like this:
Bolt size- Major dia of stud - Thread pitch
M12/1.75- 12mm or .472"- 1.75 or .069"
1/2-13- 1/2 or .500- 13 or .077
So basically the major dia and the thread pitch are close but not exact. Being as the 12mm major dia is smaller than the 1/2" is the reason why you can screw a M12/1.75 bolt in a 1/2-13 nut but you can't screw a 1/2-13 bolt into a M12/1.75 nut. Now I am talking about screwing them together by hand, with the proper power tools you can make it work either way but not recommended. There are a few other sizes of bolts that will do the same as these. So just be careful when you are using nuts to size bolts and visa versa. If you are having the threads chased then they should be able to figure out what the threads are. Good luck and I hope this helped explain it a bit.
I want it due to the shear inability to continue life without it!!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
cdnbluez wrote:You're lucky she called, my wife would have kept on driving! "Noise? What noise?"
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
cdnbluez
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
2005 S40
2006 XC70
2014 Mercedes E350
Alecw81
- Year and Model: S70 GLT 1998
Hey, I live in Raleigh and Durham.
I've also nearly driven wheels off before, on my last talon. I was hitting the corners on Palomar Mountain in SoCal, and popped 3 lugs and 2 studs on the back wheel, and 4 lugs and studs on the front.
jblackburn
That's where I'm from.
Sadly enough, stuff like that does happen in Durham all the time. Someone stole the spare wheel off my dad's Jeep a few years ago, and just a few weeks ago their grill was stolen off the deck during the night. It wasn't even a very nice grill
'98 S70 T5
- 2835 Views
Last post by oragex
- 22 Replies
- 6322 Views
Last post by cn90
- 34 Replies
- 6064 Views
Last post by ljsommar1
- 22 Replies
- 6145 Views
Last post by MrAl
- 341 Views
Last post by Mike Langlois
