IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
Volvo 850 Ignition Switch Replacement
NYC-Volvo
Year and Model: 850 R, 1996
Has thanked: 0
Been thanked: 0
United States of America
NYC-Volvo
Volvo Repair Database Volvo 850 Ignition Switch Replacement
Post by NYC-Volvo » Fri Mar 18, 2011 1:31 pm
How To Change The Ignition Switch
Volvo 850
I just changed the ignition switch in my 1996 850 R, and I’d like to share the process with you. I’ve taken photos to make it easier for you to follow along.
I rate this job as easy. I am not a mechanic, but I am handy. This repair took me 18 minutes from start to finish. So that 18 minutes includes the time it took me to gather my tools, go outside to the car, do the repair, take photos, clean everything up, and put my tools away. 18 minutes… it was much quicker that I expected.
Tools you will need
· Slotted screwdriver
· #25 Torx driver (the shank must be at least 3.75”)
Prepare your work area
· Move the seat back
· Adjust the steering column all the way out and down
· Make sure the engine is not running and the key is in the off position
Instructions
The following photo shows the underside of the steering column...
There are four #25 torx screws that hold both the lower and the upper cover to the steering column. You cannot see the upper cover in this photo, all four screws are accessed via the lower cover. The red circles show where the screws are for the removal of the upper cover. The yellow circles show the screws that hold the lower cover. Please take note that the screws for the upper cover are recessed, and you will need a #25 torx driver with a minimum of 3.75 inches of shank to reach in.
First remove the two screws holding the upper cover, and lift the upper cover up to remove it...
Remove the two screws holding the lower cover. To remove the lower cover, you will need to lift it over the ignition key area as you pull the cover down. Once you have the lower cover off, you will have the necessary access needed for this job...
You are now ready to change the ignition switch...
Next, remove the wiring conncetor from the ignition switch. I have circled the wiring connector in red...
Hold the connector firmly and pull it out with a light rocking motion. Be careful not to damage the connector...
Next, using a slotted screwdriver, remove each of the two screws holding the switch in place...
You are now ready to install the new switch. You need to ensure that the switch lines up with the position of the key. To do this, put the ignition key in the keyhole, put the new ignition switch in place and hold it witih one hand (do not screw it in yet), turn the key with the other hand until the key and the switch line up. You will know when it is lined up becuase the new switch will be seated firmly in place. Once everything is lined up, continue to hold the new switch in place, and remove the key from the ignition...
Secure the ignition switch with the two screws...
Reinstall the lower steering column cover. Be careful to get it into place over the ignition, and be sure to line up the rubber from the directional stalk and the wiper stalk. Fasten with two torx screws...
Reinstall the upper steering colum cover. Be sure to slide the rear of the cover in first and make sure it "hinges" (see below) so it will seat properly. Install the two screws to secure it in place...
Insert your ignition key and test each position and start the engine...
This job is now complete. I hope you found this helpful.
:D
1996 850 R
Previous Volvos:
1997 850 T5
2000 S80 T6
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 8 times
jblackburn
Re: Volvo 850 Ignition Switch Replacement
Post by jblackburn » Fri Mar 18, 2011 2:20 pm
Excellent; thanks for the contribution! I have added this to the Repair Database.
'98 S70 T5
2016 Chevy Cruze Premier
FCPEURO
Year and Model: 2006 XC90 V8
Has thanked: 0
Been thanked: 6 times
FCPEURO
Post by FCPEURO » Fri Mar 18, 2011 5:31 pm
+1
This is a great how to. We will all have to do this fix at least once in our lives.
Jason VanGorden
Volvo Product Manager
[email protected]
FCP Euro - European Car Parts Specialists
Quality & Service, Guaranteed for Life
155 Hill Street, Milford, CT 06460
95 850
Year and Model: 850 1995
Has thanked: 0
Been thanked: 0
95 850
Post by 95 850 » Mon Mar 21, 2011 4:31 pm
Is this identical in a '95 850?
jblackburn
jblackburn
Post by jblackburn » Mon Mar 21, 2011 4:43 pm
Exactly the same.
'98 S70 T5
Croz
Year and Model: 850glt wagon 1995
Has thanked: 0
Been thanked: 0
Croz
Post by Croz » Tue May 10, 2011 8:16 am
I just did this swap on my 95 850, and the longest time i spent was trying to get the darn upper cover off. Someone somewhere along the adventure my car has taken had changed the upper bolts to t15 instead of t25. Once i figured that out, it was a breeze thanks to the pics and instructions here.
gerbilfood
Year and Model: 1996
Has thanked: 0
Been thanked: 0
gerbilfood
Post by gerbilfood » Sat Aug 27, 2011 2:28 pm
This post is just beautiful. I really appreciate the effort to share this. Thanks!
I would like to know if the the mechanism that creates the spring-back effect when turning the key to start the car is within the part that you replaced. Currently, my 850's key will stay in the starter position if left there. It makes getting the key into the right position a little problematic. I am hoping that I do not have to replace the lock cylinder and add another key.
Cheers,
david
D_V_ENT850R
Year and Model: 850R 1996
Has thanked: 0
Been thanked: 0
D_V_ENT850R
Post by D_V_ENT850R » Sun Aug 28, 2011 8:22 am
The switch/ electrical portion has the spring in it! I replaced mine due to I had to turn my key back for my headlights, and park release to work!
NYC-Volvo
Has thanked: 0
Been thanked: 0
NYC-Volvo
Post by NYC-Volvo » Mon Aug 29, 2011 11:17 am
Yes, I can confirm that the spring mechanism is in the switch.
1996 850 R
Previous Volvos:
1997 850 T5
2000 S80 T6
gerbilfood
Has thanked: 0
Been thanked: 0
gerbilfood
Post by gerbilfood » Thu Sep 08, 2011 10:50 am
Thanks for the info. I was able to replace that easily.
Cheers,
david
