IPD sale XeMODeX - Experts in Volvo Electronics
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
Volvo 850 Ignition Switch Replacement
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 25 times
Been thanked: 56 times
Re: Volvo 850 Ignition Switch Replacement
Post by BEJinFbk »
To avoid the issue of loose connector pins, sparks,
arcs and trying to figure out which pin goes back where,
leave the cap on the ignition switch connector in place.
It's the only thing that holds all the pins in place.
The pins all fit very tightly, so it's not the easiest connector
to seperate, but it will unplug. You may find it easier if you
remove the contact block from the column first. Your call.
The entire plastic connector body unplugs from the switch.
This is what it should look like unplugged:
870 ign switch connector.jpg (37.11 KiB) Viewed 1829 times
It should all disconnect from the contact block at the back of
ignition switch assembly as one part with all the pins retained.
If your connector looks like this, then the cap has been removed:
870 ign switch connector with NO CAP.jpg (23.59 KiB) Viewed 1829 times
If you unplug it with no cap, the wires and their pins will all fall out
and sadness follows. Especially if you didn't disconnect the battery...
rspi
Has thanked: 22 times
Been thanked: 50 times
Post by rspi »
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
kanguru007
Year and Model: 850 1994
Post by kanguru007 »
The upper bolts on my 1994 2L NA 20V wagon are T10 instead of T15 or T25!!!
The ignition switch that is not returning to the correct (lights ON) position can be repaired to as-good-as-new condition and will probably last for another 20 years: open it and use pressure-pliers to repeatedly squeeze the spring-loaded metal pad to make it about 1mm wider (sorry I didn't take a picture)
revdc
Year and Model: 850 1996
Post by revdc »
Helpful post but like Croz I found the upper cover screws were t15 and not t25 after fiddling for 15min - after getting coves off pretty easy.
Thanks
revdc
superfing
Year and Model: 96 volvo 850 Wagon
Has thanked: 2 times
Post by superfing »
Thanks for the tips. Btw the upper bolts were torx 15 on mine as well. Have both!
96 Volvo 850 wagon
85 Volvo 240 Wagon DL
bugs11
Post by bugs11 »
Completed this procedure about 10 minutes ago. Everything went according to script except on my 96 850 Turbo the steering wheel top cover screws were Phillips head rather than Torx head, the lower cover was held on with T25. I only spent 4-5 minutes trying T15, T10, and T25 before I got a light and looked in the opening. The date stamp on the plastic covers indicate they were made in Feb. 1996.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 378 times
Been thanked: 1184 times
You might be on your third ignition switch, Bugs.
I bet someone lost the Torx and used Philiips as replacements.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
bugs11
Post by bugs11 »
Took a picture of the screws holding my cars steering column covers together at the time I did the install (just posting it now). The Phillips head screws look original to me, but what do I know.
emac1507
Year and Model: 1995 850 turbo
Post by emac1507 »
Croz wrote:I just did this swap on my 95 850, and the longest time i spent was trying to get the darn upper cover off. Someone somewhere along the adventure my car has taken had changed the upper bolts to t15 instead of t25. Once i figured that out, it was a breeze thanks to the pics and instructions here.
I just did my 95 850 Turbo and the and the upper cover bolts were also t15. Maybe it just this model year. But the pictures and instructions sure made it easy and it works great. Thanks.
