hoping you can help.
Just bought a 1996 850 2.0 auto with 219,000 miles on it from some people who were going to scrap it, the garage told them it needed a new transmission because of a loud grating noise whenever you put it in reverse, so I bought it to break for parts but I found out the real problem is the starter is switching on everytime you go into reverse!
I thought this would be an internal fault in the inhibitor/reversing light switch so I removed the battery, airbox etc and took this off the trans and took it apart expecting to see bits of copper all over the place bridging two of the tracks but all looks good and having tried connecting only the reversing light contacts in the switch, the starter still kicks in meaning probably the fault must lie outside this switch. Switch appears to be part of a small loom which goes into a multiplug with metal retaining lever.
Anyone had this fault or know what all the wire colours or pin numbers are for this plug to help me trace the fault? If I knew which was the reversing lamps switch part I could maybe cut it to solve the problem if it becomes a case of scrap the car or live with no reversing lamps, that is unless I can find the short.
Presumably the other tracks in the switch tell the trans brain to keep car in low gear etc, and the mechanical connection to the gearbox only does reverse, drive neutral and park?
If anyone has heard of this fault and what the problem might be please reply. I have searched the net and found no reference to it.
Thanks
Will
