XC90 Mystery Coolant Issue
jtwarne
Year and Model: XC90, 2005
Post by jtwarne »
My 2005 XC90 2.9 is using a ton of coolant; refilling every week. If the "low coolant" message wouldn't come on, I would not know there was an issue. Car runs fine (even in cold MN winter), no funky smells or smoke, temperature gauge is normal, never overheated, no check engine messages. Brought it to the dealer 4 times for this. The pressure test was fine 2 times. Nothing in the oil, no puddles under the car, no leaks detected when car is idle. They're not sure what's the matter. 60k miles (all city driving), no warranty, original owner...ideas?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Does it ever run rough on restart after driven for 30 or more minutes and then shut off 20-40 minutes and then started again?
The Blue Whale
Year and Model: 06 xc90, 2011 xc60,
Post by The Blue Whale »
Could it be collecting in your skid plate and not dripping out until your car is in motion? I had a v70 one time that had a tiny leak in the radiator that was unnoticable unless I left the car parked for a long period of time. The leak would just collect in the air dam and stay there until I moved the car.
mgjonesin
Year and Model: XC-90 '03 T6
Post by mgjonesin »
Have the oil tested for coolant (NAPA has a kit you send away to a lab). Mine had the same problem and it was the oil pan mounted oil cooler. I replaced it and the coolant stopped dissapearing. Make sure you change your oil to get fresh oil in there if you find antifreeze in there.
Koala357
Year and Model: XC90 AWD 6T 2004
Post by Koala357 »
I Just got my 04' XC90 back for the second time after being pressure tested and oil checked, still can't find why it disappearing. UGH!!! I love my Volvo but please already!
huzzsaba
Year and Model: 2004 volvo xc90 2.5t
Post by huzzsaba »
I hope I am wrong but check out this thread about coolant leaking into the transmission
https://www.matthewsvolvosite.com/forums/viewtopic.php?t=47033&f=9
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
