I just bought a 98 850. I can not get the CD player to work.
I assume that a CD is stuck in the 6 disc changer, that is trunk mounted.
I pressed the green eject button on the changer. The cartridge will not eject.
Does anyone know to solve this problem ?
Thanks Rottman
850 CD cartridge ejection
I have a similar problem here, and unfortunatelly every time it happens, I need to disassemble the disc changer.
once you remove the top cover, 6 phillips screws, if you look in the back of the cd changer and under the magazine with cd's you'll see a small metal part in the middle just press it and magazine ejects.
This is the only way I had found. In my disc changer sometimes when a switch the key to position 2 the disc changer ejects a the cd stay inside it. If somebody know something about it please help.
- 27 Replies
- 5745 Views
Last post by Rattnalle
- 1125 Views
Last post by bmdubya1198
- 14 Replies
- 1898 Views
Last post by kallekula
- 13 Replies
- 2105 Views
Last post by 454cid
- 4728 Views
Last post by tryingbe
