Rough idle and then dies
I have frequently gone tostart my 95-850 na and it would act as if the battery was dead. I would jump it off and it was fine. Since my door lock key ring battery went dead it has not done it for about a month, I thought this might had been the problem. I parked it Fri after work and started it fine Sun about 2. Went out this morning it started and went dead then would not start back and the bateery was dead after attempting to start a few more times. I came home this evening and charged it for an hour and it kind of wizzed over alot longer than usual b4 starting. I let the car set there for 20 mins and backed out of the driveway and gave it some gas and it went dead and as I tried to start it it would almost get to the point to start up but never did. I think it may be a fuel pump or bad gas any suggestions are apperciated. TKS
bobsnow100
- Year and Model:
First thing I would do is get a new battery or have it checked to make sure it isn't bad.
A bad battery can cause all sorts of weird things to happen.
I would also check for codes. If there is a problem your computer should register the fault.
- 5641 Views
Last post by resource
- 2010 Views
Last post by volvolugnut
- 2074 Views
Last post by erikv11
- 1178 Views
Last post by jimmy57
- 4713 Views
Last post by oldvolvos
