service light
fields 100
Year and Model: s 60 T-5 2013
Post by fields 100 »
Does anyone know how to reset that service light on 1998 s70 t5? I tried the remedy with a key positions ##1 & 2, while holding odometer button without success. Not big of a deal, just nice to see that these display lights are 100% in the dark.Thanks.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
97-98 DEALER ONLY
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Or disable it permanently: remove the bulb from the dash. Takes 25 min or so and is a great improvement :wink:
'98 S70 T5
2016 Chevy Cruze Premier
Juan62
Year and Model: S70 T-5M 1998
Been thanked: 2 times
Post by Juan62 »
You can purchase a Volvo Reset Tool for this model at www.partsgeeks.com (under tools) for about $120.00 I have one for my 98 S70 T5-M and it works. If you plan on keeping the car, then its a good investment.
98 S70 T5-M Brick for life
lexmia
Year and Model: 1998 V70
Post by lexmia »
You can reset the Service light with an inexpensive interface such as the one shown here:
http://www.ebay.com/itm/Volvo-Serial-Di ... c6&vxp=mtr
If you have a laptop with a serial port or a USB to serial adapter, using this $12 adaptor, you can hookup the car to your laptop and using the Volvo FCR software, you can reset the service light.
I have used this combination since 2008, when I paid $35 for a similar adapter.
I know this thread is old but this info should help.
Good luck,
AS
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I have a disk and cable that came with my OBD-II code reader, I wonder if it will work.
Do you think that $12 eBay thing from China is safe to poke around in your car's ECU with?
kevins s70
Year and Model: 2007 XC70
Post by kevins s70 »
Unless you want the service lite i would just remove bulb. It is not difficult to do and guaranteed never to come on again.
jblackburn
AND THEN JUMP ON IT. Piece of annoying junk.
'98 S70 T5
lexmia
Post by lexmia »
The $35 adapter I bought on ebay in 2008, chinese too, had the pins in the OBD connector, with sharp edges and almost no lead in. I had to pile them a lil bit , but the thing works; it does turn the light off and I still get to benefit from the service reminder light.
Just in case anyone wonders, I have no relation whatsoever to the ebay seller.
Look at the feedback the seller on ebay has. If they sold crap, their feedback would bottom.
valvster
Year and Model: 850 1996
Post by valvster »
I got one of these but from a seller in OZ.
http://www.ebay.com.au/itm/VAGCOM-USB-O ... 4aa878ccb0
My netbook does not have a serial port so this one with USB works just fine with Vol -FCR.
Make sure it has the FTDI chip in it, all the drivers can be downloaded from the FTDI website and set it to use com 1.
My car ('97 850)rarely throws codes so the only thing I've used it for is resetting the service light.
Valvster
