S60 nonturbo code p0068
lesleysvolvo
- Year and Model: S60, 2002
I just replace the oil trap and cleaned the injector rail and now I'm getting the P0068 code. Car starts and idols ok, but when I put it in reverse or drive it stalls. It also surges when you reapply gas after idling when driving down the road. Has also stalled at idle when coming to a stop. Any suggestions?
lesleysvolvo
Will do, thanks and I'll update
lesleysvolvo
All connectors are seated and tight...was advised it might be the mass airflow meter, so changed it out....runs slightly better, but not good. Stalls when coming to a stop and hard to keep running. So really not much of a change at all.
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
If it's a 2002 non-turbo, it may be the ETM (electronic throttle module). It may also be a loose hose...you could've knocked the intake hose loose while doing the work, and while the clamp is still on, the hose is loose and allowing unmetered air in (I kept getting overboost codes on my turbo S70 from a loose intercooler hose letting metered air out).lesleysvolvo wrote:I just replace the oil trap and cleaned the injector rail and now I'm getting the P0068 code. Car starts and idols ok, but when I put it in reverse or drive it stalls. It also surges when you reapply gas after idling when driving down the road. Has also stalled at idle when coming to a stop. Any suggestions?
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
- 3510 Views
- 11 Replies
- 1331 Views
Last post by MadeInJapan
- 1511 Views
Last post by rspi
- 1692 Views
Last post by oldironsights
- 711 Views
Last post by 93Regina
