Looking for part name and/ or number
elchopperfreak
Year and Model: S70 T5 1999
Post by elchopperfreak »
My wifes car was recently on an accident, the front plastic part on the dash that holds the security system light broke in pieces.
I need the name and or number of the part so we can find and order one.
Is it the actual plastic dash? What is it called?
Heres a diagram, its the part with red x's marked
Is it a complete part?
I thank you in advance for your help
The car is a 1999 s-70 T5
pkc303
Year and Model: 1995 T-5R Yellow
Has thanked: 1 time
Been thanked: 3 times
Post by pkc303 »
I looked it up on VADIS. It appears to be part of the entire dashboard. In other words, the top, is a separate part, and the under part is another part. The part number for the part you want is 9420907 for a beige interior, replacing older part number 94276999. That part is fragile. I have to replace one on our '97 850R.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
joegekko
Year and Model: S70 GLT 1998
Post by joegekko »
I need to replace this in my '98 as well.
From the outside looking in it appears that the VIN plate is just held in with some sort of pop rivet, is this correct?
pkc303
Has thanked: 1 time
Post by pkc303 »
We had our dash out in the '97 850R, and I believe that is correct.
elchopperfreak
Went on the hunt today, found a dash cover in tan, but not this part, the guy has an almost complete 1998 s70 in parts, cheap.
VolvoTurbo850
Year and Model: 1994 850 (T5)
Post by VolvoTurbo850 »
I think your referring to the plastic black piece which appears to be running just below the windshield and sometimes contains the flashing security light. This is actually part of the whole dash and is not sold as a separate piece. You can unscrew it by removing the cover outside the car right under the windshield wiper stalks as well as a few other screws inside the car.
The dash pad is a separate piece and contains the passenger air bag.
Quite often these develop cracks on the front and can squeak if the support bolt brackets which are plastic break.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
elchopperfreak
Correct. That is what im looking for.
So theres no separate number/ name for it?
Thanks
VolvoTurbo850
i do not think your going to want to buy a new one at $$$$$$$. You should just buy a used dash. Most of the parts which are the wood inserts can be removed from your old one and installed. If there are cracks in it but still supports the dash your better off trying to repair it or glue it together.
Are you just trying to keep your volvo going or are you trying to build a showcar? Im sure there are not too many Volvo;s in Puerto Rico
The Fleet
2001 V70 (NA) 2.5
1994 850 Turbo (T5)
elchopperfreak
You would be amazed of ther very large amount of Volvos on the road here, among Mercedes, BMW's, Jags,Audis, Porsche etc and all the Japan imports..
What is hard to find are junked Volvos.
I just want to replace the dash as it was, I dont think it can be glued back.
This particular T5 has a bit less than 50 thousand miles in it, and look and feels like new.. My 93 850 has 95 k miles , my dad has a full on IPD built 740 turbo stick shift..
elchopperfreak
On the other hand, not too many S70 t5's. Way too expensive here..
