what years had questionable ETMs?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
Sorry for a rehash of a common topic but the posts I had book marked on many topics didn't give me a "for sure" answer.
Our 2001 T5 had a bad one and then a bad replacement...now the wife found a 2006 Ocean Edition she wants with about 100K miles. I know we can look for the sticker of a replacement ETM but I'm curious if there was a year they went to a different solution. I seem to recall the replacements have the same failure point so that tells me Volvo never started putting a better design in.
Did they replace them with the newer body designs at all?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
'99-'02 were the bad years.(Magnetti Marelli units)
I believe starting with '03 they came with a better design, not the potentiometer design of the early years.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Everything I've read about ETMs indicates that the replacement units that Volvo fitted (and is fitting) has the same part number (and design) as older units.
No redesign was embarked upon or was compatible with the ECUs (apart from XeModex's units which are aftermarket)
jda2000
Post by jda2000 »
precopster wrote:Everything I've read about ETMs indicates that the replacement units that Volvo fitted (and is fitting) has the same part number (and design) as older units.
My 07 S60 has a completely different ETM that is not a Magnetti Marelli unit and does not use potentiometer film :)
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
jda2000 wrote:'99-'02 were the bad years.(Magnetti Marelli units)
This is correct. What stinks is that even the replacement unit has a chance of failing. They did not redesign it or anything.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
99-01
The only 02s were a VERY small minority of S70 and V70 NON turbos early months into production.
(Probably all done by Dec 2001
2002V70
Post by 2002V70 »
JRL wrote:99-01
All Non-Turbo '02 have the bad ETM. Mine is a late '02 build (June '02?) and has the bad design. replaced once at ~70K miles. Now has ~140K miles and is still fine.
JRL
Post by JRL »
I was told a few but now you've proven otherwise, but in 2002 it is JUST the non turbos, that I DO know!
JRL
Post by JRL »
Well, time to eat crow or mud!!!
Apparantly ALL 02 C70s came with the "bad" Marelli-Magnetti ETMs!
(I just found this out today as Volvo replaced (under warranty) the slightly glitching ETM out of my daughter's 02 C70 with 95K miles!
carboncow
Post by carboncow »
Thanks gang sounds like the 2006 we are looking at is safe!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
