hi
i have a 98 v-70 wagon and am trying to remove the motor.
i have the door panal off and can not remove the plate that the motor is on.
any help would be great
thanks brian
window motor replacement
smokingslash
- Year and Model: 85097awd
VolvoTurbo850
- Year and Model: 1994 850 (T5)
Brian there are bolts holding the regulator which is the metal place. You also have to remove the clips which connect the regulator to the window glass. This way you can get to the bolts on the inside of the motor.
Could i ask why your going after the motor? Usually the window regulator switch goes on these models first before the motors.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
smokingslash
hi
when i took off the panel i could not tell how to take out the motor(just to have the info).
it is the switch as the windoe will go down some times but not up, to put it up do i just send 12volts the other way?
thanks brian
thanks brian
VolvoTurbo850
I would check the switch.. and most likely replace it. The resistance is greater when it goes up than down.
After you find another switch and it continues the problem then replace the motor.
As I said before.. the 70 Series switch is known to fail specially the drivers over all other switches in the car when you consider how many times the drivers window goes up and down. Even if it not the switch you wont go wrong getting a spare.
One way of checking this is run the engine and rev the engine a bit higher to increase the power to the switch when you try moving the window up.
The Fleet
2001 V70 (NA) 2.5
1994 850 Turbo (T5)
smokingslash
hi VolvoTurbo850
thanks for the info i will start to look for a switch.
brian
brian
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Yes - And be sure that the switch is unplugged when you do.smokingslash wrote:hi
thanks brian
- 4880 Views
Last post by dcm0123
- 1029 Views
Last post by FuddleyPJones
- 1716 Views
Last post by mikealder
- 506 Views
Last post by HelpingJoe
- 3219 Views
Last post by BEJinFbk
