Can someone give me some direction/ideas as to why the drivers side ,front door on my 1998 S70GLT won't open when using the outside door handle ? Please .The inside door release works fine .Thanks in advance .
Billy I.
door handle/lock
JRL
- Year and Model: Several
- Been thanked: 16 times
You have to take the door panel apart, the rod came off
Sometime they fall out and sometimes they break off the actualtor, if that's the case you will need a new or used door lock assy.
VolvoTurbo850
- Year and Model: 1994 850 (T5)
keep going .. you have to remove the torx bolts which are 90 degrees from the door handle where the latch is located... this should free up the handle so you can peek inside.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
The bolts holding the lock to the door ?and or the bolts under the plastic cover hiding the door handle mount bolts ? I got this far ,but when I start to move the handle it feels like its still attached in there somewhere .I'll look further into it tomorrow ,wether permitting .Thanks
Billy I
Billy I
- 1624 Views
Last post by Clemens
- 2796 Views
Last post by a50sGreaser
- 1116 Views
Last post by Volvo S80
- 1959 Views
Last post by matthew1
- 1466 Views
Last post by joevar
