I just replaced my alternator and had my battery charged (slow trickle charged it to 'rebalance' the acids in the fuel cells). Now I just got my car back and the windshield wipers don't work. I don't hear any motor when I turn them on. I already checked the fuse and that's fine. Is it the wiper motor that went bad? And why all of sudden after my alternator was replaced?
Thanks in advance.
1998 S70 windshield wipers not working
VolvoTurbo850
- Year and Model: 1994 850 (T5)
You need to remove the cover under the blades to see if it is working or not.
I would also determine if your windshield washer lever is working. Pull it forward so you can see if it is in sequence with the headlight wipers.
If not then check the motor and the wiper transmission... spray some lubricant in the joints or whack it with a rubber mallet. They sometimes stick when sitting around.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Don't overlook the simple things - check fuses first!
'98 S70 T5
2016 Chevy Cruze Premier
Just a follow up over a year later:
The shop said we had a bad motor and of course wanted to charge about 200 bucks to replace it. So my husband replaces the motor himself (found a $20 motor from a scrap yard) and the wipers still didn't work. Turns out the wiper switch was disconnected! And this switch couldn't have accidentally come undone (it wasn't loose). My husband simply snapped it back in place and voila, the wipers worked. We find it very suspicious that this happened the day we got it back from the shop, especially considering how adamant they were that it was the wiper motor that failed. Did they not even check the switch? We paid for that crap diagnostic as well. We now don't trust our mechanic.
madspeed50
- Year and Model: 1998 S70 T5m
that sucks. lotsa crooks out there
Sent from my rooted, rommed Galaxy Nexus....
- 1478 Views
Last post by SuperHerman
- 1587 Views
- 13 Replies
- 2332 Views
Last post by MoVolvos
- 14 Replies
- 2187 Views
Last post by MrAl
- 1589 Views
Last post by HereWeGoAgain
