Check the vacuum line to PTC for PCV
This topic is in the MVS Volvo Repair Database » GearWrench 12 Piece X-Beam Wrenches
Dad03
Year and Model: 1995 850 Turbo
Post by Dad03 »
I recently changed out the PCV system at the first signs of it being clogged (leaking oil, white smoke from tube).
I ordered the kit from IDP. The kit "kinda" fit but thats not the reason for the post.
After installing the new PCV the syptoms did not subside. After scratching my head for a week I decided to pull the PTC and re-clean again. I started the car and noticed the vacuum suction from the small line that connects to the side of the manifold was weak. I checked it at the manifold nipple and it was strong. I ran a new vacuum line from the side of the Manifold to the PTC.
I just routed it around the manifold.
So far it appears the crankcase pressure are under control. No leaks in 2 days!
Not sure if the small tube in the kit was clogged, bad, cracked, ????
If you just changed it out and not having any sucess check the vacuum line.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
You may have pinched it or broken the plastic tube inside as you were installing the new hose.
If you have smoke at idle from the dipstick/lots of oil around the intercooler always double check that hose!
'98 S70 T5
2016 Chevy Cruze Premier
