First Time Doing Rear Brakes
- Year and Model: Many Volvos
- Been thanked: 76 times
If you have no vibration under braking and the rotors otherwise look OK then just change the pads. If the pads come out way out of balance in terms of wear you may need to look at a new caliper or at least address the slide that the caliper rides on.
VolvoTurbo850
- Year and Model: 1994 850 (T5)
Why not take it to a mechanic who wont charge you for inspection and see what is reported back. If your going to dwell into a brake job why not see what is required since you will have it all taken apart anyway?
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
I took it to a shop yesterday and they said the calipers and most likely the rotors needed to be replaced. I'm not opposed to replacing everything I just want to know what I should be looking at to see if I indeed I need to.
How long have they been on there? If they've been on there 3 or 4 years I'd go ahead and just replace the rotors. There is a minimum thickness spec which the mechanic should be able to provide you from alldata and measure the rotor thickness. If money is an issue and the rotors aren't warped they'll probably hit them with a die grinder and clean them up some and just do pads if you ask nicely and explain that money's tight.
1998 V70 GLT, 15G swap
Fairfield, CT
Fairfield, CT
precopster
- Year and Model: Lots
- Been thanked: 128 times
In a brake rotor diagnosis either the rotor thickness falls within specification or it doesn't. If there is vibration under brakes you may need new rotors as once the warped area has been flattened by machining the thickness may be under specification. The minimum thickness for most non-ventilated Volvo rear rotors is around 8mm.
The only reason to replace calipers is if the pad material is uneven in wear when comparing one pad to another and they have diagnosed that the caliper piston(s) is seized or the sliders are damaged beyond repair.
VolvoTurbo850
Yup as precopster said above ... I would just replace everything at this point. If your calipers were bad then chances they were doing a number on your rotors. The rotors should be cheaper than the calipers so I would change everything.
While your in there check the brake flex hoses to make sure they are not cracked. If so replace them too.
Once you do all this, chances are you will be good for a long time.
The Fleet
2001 V70 (NA) 2.5
1994 850 Turbo (T5)
Hi,
I did my rear pads and rotors a while back and now regret not replacing my ebake parts (FCP has a kit) as the rear pads tend to bind on my 850 and drag if I use the emergency brake- have to get out of the car and wiggle the cables under the rear wheels a bit to get it free. You might want to replace those springs and things while you have the rotors off.
1994 850 wagon, 5 spd, 373,000mi
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
+1. There's basically three degrees of replacement for rear brakes:
a) Just the pads
b) Pads,rotors,shoes,hardware
c) Pads,rotors,shoes,hardware,calipers
Note where calipers shows up. If you're replacing them, replace EVERYTHING while it's apart.
Deviation from that list is of course possible, but inevitably leads to wishing you hadn't been cheap about it.
a) Just the pads
5 others that came and went
- 2158 Views
Last post by foggydogg
- 56 Replies
- 5042 Views
Last post by jonesg
- 15 Replies
- 2796 Views
Last post by SonicAdventure
- 1659 Views
Last post by j-dawg
- 1811 Views
Last post by FCPEURO
