locked steering wheels
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Miss Volvo 2001
Year and Model: S60 2001
Post by Miss Volvo 2001 »
Did anyone had this problem before? Yesterday, I came back to my S60, 2001 and everything was locked. Could not turn the key in the ignition, neither the steering. Had the feeling the anti-theft system was locked. Is there a code or something to unlock this or can it be another type of problem?
Thanks
z28chuck400hp
Year and Model: 2001 xc
Post by z28chuck400hp »
sounds like you have some pressure to the steering wheel..are the front wheels up against a curb or other object? try putting the key into the ignition switch....if you cant turn the key try turning the steering wheel hard to one side while trying to turn the key.. if it does not work then turn the wheel the other way while trying the key..you may have to turn the wheel pretty hard to free it if the front tires are putting force against the lock . good luck
