thnks
1998 volvo v70 hatch wont open
aimylynn1982
- Year and Model: 1998 volvo v70
my hatch wont open if I click the release it makes the noises just nothing happen? key doesnt work, and cant seam to see whats wrong by taking the panel off that goes to it any ideas?
thnks
thnks
VolvoTurbo850
- Year and Model: 1994 850 (T5)
could you not use the internal lock or levers to open it?
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
turbovagen
- Year and Model: v70 t5, 2002
tyipcally disconnected solenoid...sounds like the case here.
One thing that worked a long time for me was to push the door hard forward at the same time I was pulling the release. That began working only sometime, but got better after I lubed the catch when I had it open.aimylynn1982 wrote:my hatch wont open if I click the release it makes the noises just nothing happen? key doesnt work, and cant seam to see whats wrong by taking the panel off that goes to it any ideas?
thnks
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
bobsnow100
- Year and Model:
As someone pushes the release button,try pulling up on the trunk at the same time. See if you can get it open that way. I had an issue like this and once . Once opened I sprayed white lithium grease into the mechanism and got the all lubed up and it has worked fine since then.
Fish stick88
- Year and Model: 1994 - 850 Sedan
it's possible that one of the struts/springs may be out or discharged. if you click it, can you then open it from the back if you pull it up?
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
- 1305 Views
Last post by configsys
- 1236 Views
Last post by zanzabar
- 13 Replies
- 34701 Views
Last post by Stephen0523
- 1487 Views
Last post by panda30
- 1118 Views
Last post by Geno9707
