OBD II & ABS TRACS Light
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Nope, a standard scan tool won't read them.
I would attempt to clean up your wheel sensors and reluctance rings on the axles; it sounds like the ABS system thinks a wheel is slipping when it's not. An old toothbrush and solvent like Simple Green or something works well for this.
'98 S70 T5
2016 Chevy Cruze Premier
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
If after the cleaning, the lights are still lit, you will need to get the codes read because then we will have to start replacing parts. No need just throwing parts at the system. Good luck.
jblackburn
Yep
'98 S70 T5
It sounds like your abs module is cracked. My OBDII read those exact codes fine, the noise you hearing does it sound like your in 3rd gear and its slowing you down as if your brakes are on?nwhitney wrote:My ABS & Tracs lights came on & I have some intermittent grinding sounds (feels like it's coming from the front) while braking. Will that throw any codes and would a OBD II scanner read those?
<3
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Known issue with the ABS module.nwhitney wrote:My ABS & Tracs lights came on & I have some intermittent grinding sounds (feels like it's coming from the front) while braking. Will that throw any codes and would a OBD II scanner read those?
99% chance you have bad solder joints.
Click here and get to reading:
http://home.earthlink.net/~vicrocha/
This guy has been around a while, but there
are plenty of options for the fix, including DIY.
MVS member Matty Moo is getting great reviews!
Good Luck!
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
On the topic of brakes related to your post, I had similar issue with ABS/TRACS lights coming but not really any noise but you could feel resistance like the brakes were on. It turned out my front calipers were frozen, the car did some sitting and previuos owner did not care for her...good thing he was second owner for only 3 months. I knew it was the brakes but wasn't sure exactley how much needed to be done, so I brought it to my inspection shop and they told me the front calipers were fronzen.jobean727 wrote:It sounds like your abs module is cracked. My OBDII read those exact codes fine, the noise you hearing does it sound like your in 3rd gear and its slowing you down as if your brakes are on?nwhitney wrote:My ABS & Tracs lights came on & I have some intermittent grinding sounds (feels like it's coming from the front) while braking. Will that throw any codes and would a OBD II scanner read those?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Thanks for the responses. I thought the ABS might be needing a repair. What I think is going on is the front brakes are very close to if not metal on metal and this gives me the grinding sound then my brakes overheat causing the lights to come on. This has happened before. I'm about to go change my pads and inspect the calipers & rotors.
- 22 Replies
- 5994 Views
Last post by hausmeister
1999 S70 ABS/TRACS light on after resolder
by jlferreira » » in 850, S70, V70, C70, V70-XC 1992-2000 - 1 Replies
- 800 Views
Last post by jose456891
- 2171 Views
Last post by rguzz
- 3746 Views
Last post by rguzz
- 2482 Views
