Noticed a clicking from the front wheel when i rolled into the garage. It seems to increase with speed. Took it down the road and noticed clicking when i take my foot off thegas, but seems to go away under acceleration?
CV failing?
I recall earlier this week an odd slipping feeling when i pulled out of the driveway....sort of like the wheels breaking loose....
99 V70XC Left Axle Question
voodoorobaz
- Year and Model: 1982 Volvo 245 DL
Just had this same symptom which I thought was going to be CV joint due to a torn boot which I failed to repair but upon removal of tire I discovered bearing assy had broken. Might want to pull the tire off and inspect as soon as possible. Could be that it is the CV joint but give that bearing assy a good looking over.
1998 Volvo S70-Gone
2002 Volvo S60 T5-Gone
2000 Volvo V70 XC AWD-Gone
1983 Volvo 245 Dl-Gone
1982 Volvo 245 DL
2013 GMC Terrain with 3.6l
2006 Cannondale Bad Boy Use for Commuting to work
1982 Volvo 245 DL
JRL
- Year and Model: Several
- Been thanked: 16 times
Probably, possibly
You need to do what was said, INSPECT it
Volvoagain
- Year and Model:
Lifted the car up this morning....Everything appears solid....No wheel movement, axle boot looks good, no play...
I'm going to put it on the lift in the morning and take a harder look. I have an axle just in case, cant hurt...
I did notice that both Strut mounts are done....might as well rip it apart and replace them as well.
- 2299 Views
Last post by GazmorGuri75
- 3051 Views
Last post by mouseskowitz
- 13 Replies
- 3043 Views
Last post by 98v70dad
- 674 Views
Last post by Darksim
- 1341 Views
Last post by gtman220
