2002 S80 ac blower / drain
The ac blower on my 2002 Volvo s80 blows cold air through the ac vents just fine, until the evaporator ices (???) and then no air comes through. If I shut the ac down for a while, it then works well again. Is this due to an ac condensation drain problem, or something in the ac system controls? Where are the plenum chamber drains located.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
it is because either the evaporator temp probe is defective or it is covered with crud making it insensitive to the temperature.
It is stuck into evaporator case above and to the right of accel pedal under dash. Has a green electrical connector.
hi,
i think we have the asme problem, i am not sure that the unit freezes.
did you find the cure?
thanks,
avishay.
[email protected]
thanks,
avishay.
[email protected]
- 13 Replies
- 6180 Views
- 3352 Views
Last post by Cees Klumper
- 46 Replies
- 12755 Views
Last post by 93Regina
- 2331 Views
Last post by regent
- 14 Replies
- 2986 Views
Last post by Mike Langlois
