A couple days ago the flashing arrow started. The car is driving fine, but I don't want to screw things up by continuing to drive it. I took it to Autozone and they said there were no codes. I then went to a mechanic and they ran it on 2 different OBD II devices and no codes came up again. I have tried to reset the warning lights by holding down the odometer reset button and by shifting from Park to L quickly. Neither worked... does anyone have any other ideas about what could be wrong or how to reset the warning lights?
Thanks for any help.
Ryan
2000 V70 Flashing arrow but no codes
baylorbrown
- Year and Model: V70 2000
JRL
- Year and Model: Several
- Been thanked: 16 times
Why on Earth would you hold the odometer reset?
Anyhow
How many times did you row the shifter? You need to do it about 15-20 times
If that doesn't clear it you need to take it to Volvo
You WILL have stored codes but only VIDA can read them
Anyhow
baylorbrown
I read how to do it on this site:JRL wrote:Why on Earth would you hold the odometer reset?
https://www.matthewsvolvosite.com/2008/1 ... -c70-xc70/
Maybe I miss read?
Yes, rowing the shifter 10-20 times should work. Other than the light, you haven't noticed anything with the car's shifting or performance?
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
2004 C70 HPT (wife)
1998 V70 GLT (son)
JRL
Uh.... yeahbaylorbrown wrote:I read how to do it on this site:JRL wrote:Why on Earth would you hold the odometer reset?
Maybe I miss read?
That to reset your service light
baylorbrown
I have tried rowing the shifter 20-30 times and it hasn't cleared the light.dbm123 wrote:Yes, rowing the shifter 10-20 times should work. Other than the light, you haven't noticed anything with the car's shifting or performance?
It has been driving fine, no rough shifting or high rpm revving.
Can't figure it out??
JRL
Well, something's going on and I suggest you get the stored code pulled at Volvo
You could be doing irreperable damage to your transmission by continuing to drive it
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Standard OBDII scanners cannot pull transmission codes. Those must be read by a Volvo scanner.
'98 S70 T5
2016 Chevy Cruze Premier
baylorbrown
Drove it today for about 30 minutes (was planning on going to the dealer tomorrow) the arrow flashed the whole way. When I got back in to go home, it was no longer flashing. Should I still take it to the dealer tomorrow?
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I'd say getting the code pulled would help my peace-of-mind. Usually that arrow will only flash for something serious.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 2486 Views
Last post by polskamafia mjl
- 1114 Views
Last post by Nick777
- 1034 Views
Last post by New2Volvo98
- 947 Views
- 1369 Views
Last post by RickHaleParker
