economy and sport option change
tkende06010
- Year and Model: 850glt,1996
Hi all, being a new Volvo owner, I had a quick question. Does anybody know if you can go from economy to sport while driving? i am not sure if it is supposed to be set before you start driving, and can you put it in nuetral while moving, to change it? Thanks
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Absolutely; if you need to pass or something, just flick it to the other mode. Flooring it works too.
I only leave my car in Sport mode if I'm driving aggressively on curvy back roads; otherwise it's just annoying and will drop 2 gears at the slightest touch of the gas pedal.
'98 S70 T5
2016 Chevy Cruze Premier
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
+1. Don't even pop it into neutral. Just flick the switch.
I run my 96 855 N/A in Sport mode all the time, unless I'm trying to make a gas station on my last pint of fuel.
By contrast, I run the 97 854 GLT in Economy mode even when I'm sticking my toe through the grille; the higher shift points really aren't helpful in the low-end-optimized light pressure turbo engine.
5 others that came and went
- 795 Views
Last post by CIK7
- 1153 Views
Last post by bmdubya1198
- 49 Replies
- 9479 Views
- 26541 Views
- 3583 Views
Last post by MarcM
