Is My Engine Running Hot? 87C thermostat; it's showing 95-10
tolian2
Year and Model: 1995 Volvo 855 5sp
Post by tolian2 »
97 854GLT 127K miles
I was checking the temperature via ELM OBD2 reader.
I put in a new thermostat 87C one from Calorstat.
Drove around with the live reading and it was showing anywhere from 95 C to 100 C.
Is this normal? Isn't the idea of thermostat to keep the engine at 87C?
The temperature gauge in the cluster is slightly above 3 o'clock position and stays there once the engine warms up.
Any ideal?
thanks a lot.
Also what temperature is the red zone on the gauge (overheating)?
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
Mines is about level too. about 3 o clock, doe it seem like its running hard? are you burning up a noticable amount of oil?
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
I'm pretty sure the temperature designation only corresponds to when the thermostat will actually open. It doesn't mean it will necessarily hold the temperature exactly at that number. If your temp gauge is holding perfectly with no fluctuations, then there is nothing to worry about.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
tolian2
Post by tolian2 »
there's no fluctuation of the gauge whatsoever. once it get's to slightly above 3 o'clock it stays there.
it's only in scanmaster-elm software that i could see temperature changing from 95-100 back and forth, etc.
