Remove Bevel Gear Option
jjsull
Year and Model: 2000 V70 XC
Post by jjsull »
Hi,
After problems with the Bevel Gear and VC one writer has mentioned that I may be better off totally removing the bevel gear due to the loud whining from the unit without the drive shaft installed.
Does anyone have experience with this. How do I "seal" the output shaft area?
Any help appreciated.
jjsull
Post by jjsull »
2000 V70 XC 131,000 miles
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
I haven't done it, but did bookmark a link just in case I needed the info in the future. Check out the following:
http://www.volvoxc.com/forums/showthrea ... bevel+gear
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Again, from VolvoXC, seems like a very easy project.
http://www.volvoxc.com/forums/showthread.php?t=18467
-Remove passenger side axle.
-Unbolt bevel gear
-Replace metal collar with some Loctite or similar
-Replace axle.
Done.
I'll be doing this in a week or so. I'll make a DIY writeup.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
jjsull
Post by jjsull »
Thanks all
