240 wagon shift problem
whtwgn
Year and Model: 1990 240
Post by whtwgn »
New to site Hello everyone.
My 240 5 speed is giving me trouble when driving downshifting to 2nd or 1st.
The car has a new clutch cable.
and also what fluid should i use for the gearbox.
the car is a 1990
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
This may be a little late but I have been away for a week.
Is the cable adjusted according to spec?
240 clutch cable adjustment.pdf
(78.37 KiB) Downloaded 141 times
You need Automatic transmission fluid type F for a manual box.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The Swedes use a synthetic oil in that gearbox but list type F as alternate.
The first gear brake that suppresses gear lash rattle causes problems with hard gear selection and even a first gear bearing failure when ATF is used.
The synthetic oil from Volvo is not (unless it has changed) stocked in US so 5w30 synthetic motor oil can be used.
whtwgn
Post by whtwgn »
Thank you both for a quick response.
Will keep you posted with results.
