I recently hit a pot hole so big that it bent my two RH side rims. The tires immediately lost air. The tire store was able to straighten them so that the tires would keep air, but they still leak pretty quickly. They recommended I replace them.
The problem is I don't know where to find new ones. The tire store doesn't sell them and tirerack.com doesn't seem to have 15" steelies in stock. The tire size is 195/60/R15. It would be great to find a local retailer to avoid shipping costs as I am tight on money, but I can't seem to locate any.
Thanks in advance,
Pat
Bent Rims-Help
look in local junkyards and online. That would be your best bet. Some tire places now have a machine that will straighten bent rims back to round, but is sounds like the place you took yours to did not. They most likely just hammered them back into somewhat of shape.
93 850 GLT sedan 156K
94 850 Turbo 189K
94 850 Turbo 189K
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Wheels off a 1996-1999 Ford Taurus (and possibly later variants, too) are the exact same bolt pattern.
'98 S70 T5
2016 Chevy Cruze Premier
el diablo viejo
- Year and Model: 98 S 70 T5 Stick
Check craigslist - auto parts - type volvo into the search. Try other nearby areas if you can't find any in your local listings.
1998 S70 T5 5 spd. 196 K Amsoil
1969 442 Amsoil
Long gone 1985 242 4spd.
Long long gone 1966 122 4 spd.
Way long gone 1961 PV 544 4spd.
1969 442 Amsoil
- Year and Model: Many Volvos
- Been thanked: 76 times
Plan B would be to pick up a used set of Cetus alloy wheels. I upgraded my son's car from steelies with two hub caps missing to a used set of Cetus wheels for around $100 + freight. It did improve the look of the car and it was cheap enough. Cetus wheel are very common, more common that the steel wheels, so they can actually be cheaper than steel wheels.
You will need to pay to swap the tires and get them balanced but you would need to do that anyway.
OK, thanks for all the help.
I've tracked down a set of rims with tires mounted on Craigslist off a '93 Volvo 960. They are 15" rims, but the tires are 195/65R15. The tires I currently have on my '98 S70 are 195/60R15. Would the new ones fit being they are slightly different in size?
Thanks again,
Pat
Thanks again,
Pat
Volvoagain
- Year and Model:
You can have yours fixed or buy remanufactured for 95.00ea
Keystone-auto
Wheel Collision in Bath, Pa
Transwheel
many more on-line.....
Keystone-auto
Transwheel
- 4400 Views
Last post by 93Regina
- 1908 Views
Last post by precopster
- 644 Views
Last post by Earn_est_89
- 2400 Views
Last post by cn90
- 1353 Views
Last post by xHeart
