AC discharge hose diameter Topic is solved
Guest
Post by Guest »
Does anyone know the diameter of the high side AC discharge hose on the 1995 850 turbo? I want to add a saddle valve to the metal part of the line so it can be properly serviced. It's a 2.4L, L5 w/dohc. Can't seem to find the high-side service port, either on the line or compressor. Thanks!
Guest
Post by Guest »
With the help of a saddle-valve and inserts for a hermetic system, I've determined it's 1/2-inch tubing.
saleem
Post by saleem »
Disconnect the compressor temperature sensor of 850 Volvos. Take the wire out and connect it directly to the clutch wire connection.
