IPD ecu update
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
yeap! and even better with IPD's HD TCV, CBV (Red spring) new Flam trap (PCV), RIP intercooler pipes/hoses K&N filter, new distributor w/cap, spark plugs, and 8mm silicone wires, new silicone hoses for all vacuum and Turbo hoses. So far, she's smokin everyone at the lights and they do eat my tail pipes!
98 S70 T5-M Brick for life
98V70T5
- Year and Model: V70 T5 1998
are you guys running with an auto trans? I want to upgrade to more power, but couldn't get a straight answer about how long the trans will hold up. Its an AISIN unit, and I've dealt with that company from playing with Toyotas the last 20 yrs, and I gotta tell you they build some really strong transmissions. They also supply Lexus.
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
read this: http://forums.turbobricks.com/showthread.php?t=10961 contains some very good information and it seems with a cooler and all else being in good condition, the trans is OK up to 300hp. Not sure if I would go that high though....
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
98V70T5
I have learned over the years a good cooler, and to lift slightly when the trans is shifting to reduce shock saves the trans. That and not beating on it 24/7.Marcobrick wrote:read this: http://forums.turbobricks.com/showthread.php?t=10961 contains some very good information and it seems with a cooler and all else being in good condition, the trans is OK up to 300hp. Not sure if I would go that high though....
I am looking for like a stage III setup, around 285hp. Looking for 15psi, exhaust, IPD ECU, R exhaust manifold (maybe), intake, and high flow cat. Honestly, the front tires can't handle much more power than stock already
Thanks
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I hate that stupid first gear - what were they thinking?!
'98 S70 T5
2016 Chevy Cruze Premier
98V70T5
jblackburn wrote:I hate that stupid first gear - what were they thinking?!
Long 1st gear ratio helps control wheel spin. This car needs a good 5sp auto like the later gens.
- 3945 Views
Last post by thudson
- 17 Replies
- 1313 Views
Last post by PatternFlyer
- 11 Replies
- 3138 Views
Last post by tryingbe
- 4475 Views
Last post by Clemens
- 2429 Views
Last post by shaker_chi
