loss of power and boost
bugsbunnies95_850t
- Year and Model: 99 v70R
ok so recently my 95 850 turbo wagon hasnt been itself . the usual pin you back into the seat isnt even close to what it was and it seemed like a light switch just shut off my power .. i started looking at my boost gauge when accelerting to see if was loosing boost and i deffinetly seem to be . whe i jam the pedal to the floor the boost needle goes as far as the gauge allows and drops to about half way down. PLEASE HELP i want my baby back !
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Have you done any recent service to it? Any codes?
First thing I'd check is the various vacuum and intercooler hoses. After that, review the Stage 0 items and replace/repair as necessary.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
DrewsT5
- Year and Model: '95 850 T5 Wagon
It could also be the Compressor Bypass Valve (CBV). Check IPD's website for some more info, as they have a heavy duty replacement part for this. But, I would check the other items vjaneczko mentioned first, if you haven't already.
bugsbunnies95_850t
ill give it all a loo and let you guys know.. thanks
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Let OFF the gas pedal suddenly at 4000-5000 RPM and listen for a "fluttering" noise of sorts - if you hear that, your CBV is definitely dead. IPD sells a good replacement.
'98 S70 T5
2016 Chevy Cruze Premier
I had this problem, low boost, checked CBV and replaced the Boost Control Valve, replaced both items with new ones (IPD kit, Blue Spring) replaced all associated vacuum lines. No Better. I had no other drivability issues (for a week) Decided to check fuel line when I had a hot start problem on a warm day. It seemed like vapor lock- I was losing fuel pressure and getting misfire codes when I would try to start it when the engine was hot. I was stumped, and called a local volvo mechanic. He said that the in tank line that goes from the pump to the housing would come loose because the tube on the housing did not have a barb, and that two hose clamps (super tight) on that hose would keep it on there. I went back and checked in the tank. It was loose, I changed the line, added the second clamp and the boost came back. yay.
Aesop's moral, check ALLLL the fuel lines, maybe save a couple of bucks.
formerly:
1996 850 Turbo Sedan
The fuel pump hose in my 850 had both a top and bottom clamp. They were both tightened as far as they would go but the top one was really not clamping the tube. As soon as I tried spinning the hose it separated from the upper tube. I have spent four days in an unheated garage tracking down a P0172 engine code and no power/turbo above half throttle and this is what the answer was. My fuel pressure at the fuel rail was 18 psi. Now after replacing the hose clamp it is up around 36 psi. I sure wish I had seen this earlier. I really do appreciate these forums.
1996 850 Turbo sedan
- 4950 Views
Last post by EKOEHLER
- 883 Views
Last post by 93Regina
- 38 Replies
- 12195 Views
Last post by mrbrian200
- 868 Views
Last post by Sommerfeldt
- 24 Replies
- 7548 Views
Last post by jonesg
