S40 t5 - help with airconditioning problem needed
frrankenstein1
- Year and Model: s4 t5
Has anyone had a problem with airconditioning suddenly not working? Refrigerant has been topped up; no leaks. Car just out of warranty. Could be a pricey problem to fix. Garage implies they have been having problems with condensers. Any information out there folks?
It would have saved you a little bit of time to read a few of the posts already on this forum. there was a lengthy one only a couple of threads down from this one, labeled "A/C starts off cold then blows warm".
Hope this helps. The very last post on that thread has a link to another forum where someone discusses how to remove a shim to fix the issue. You might also try googleing the issue. I did that and found a few different forums where people had already talked in length about this problem.
- 949 Views
Last post by GSPVX
- 2503 Views
- 225 Views
- 940 Views
Last post by RickHaleParker
- 977 Views
Last post by turtlehead
